Insert the memory card into the
camera to format it if you are receiving error messages such as "Card
Error" or "Card Not Initialized." Press the "Menu/OK" button then press
the left/right directional button to select the "SET" option. Press the
up or down direction button then press "Set Up" and press the "Menu/OK"
to access the setup screen.
Press the down directional button to select "Option 1" and scroll down
to the "Format" option. Press the right directional button to select the
format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does
not work. Rotate the scenery mode dial at the top of the camera to the
"Auto" mode. Press the "Flash" button to enable the flash mode to
provide additional lighting if necessary.Manually set up the Fuji E500 camera with your
computer
if the computer does not automatically detect it. Connect the camera to
the computer using the supplied USB cable and power on the camera.
Click the "Start" button then click on the "Computer" option and select
the FinePix Icon. Choose next on the download wizard to start the
download process.
button to select "Option 1" and scroll down to the "Format" option.
Press the right directional button to select the format option. Press
brighten the lights if the auto focus does not work. Rotate the scenery
mode dial at the top of the camera to the "Auto" mode. Press the "Flash"
button to enable the flash mode to provide additional lighting if
necessary.
Manually set up the Fuji E500 camera with your computer
download process.
Read more:
How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
necessary.
download process.
Read more:
