Question about Linksys Computers & Internet
I pushed the reset button on my linksys router. I didn't know it would wipe out my network address, etc. I went through the reinstall but I didn't see how I could set up a network with the same name as I had before. Can someone help me rename my network to the same name as I had before so my other wireless equipment will work?
luiskiev
  • 144 Answers
SOURCE: How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Posted on Nov 07, 2008
mbase213
  • 728 Answers
SOURCE: resetting my password for my wireless-g broadband router w/ a mac
 If it has been reset the password for the default linksys is admin.
Posted on Dec 12, 2008
  • 23 Answers
SOURCE: 3800HGV-B and LinkSys Dual-Band Wireless-N USB Network Adapter
Because the linksys is talking about SecureEasySetup which most lynksys routers use. The 2wire 3800HGV-B button is not a SecureEasySetup button.
Posted on Mar 18, 2009
SOURCE: My Dell laptop won't connect with my Linksys G wireless router
First check in your laptop wi fi switch is turn on if you have laptop.
Then check in computer that wi fi network adapter driver are installed correctly and enabled .
You can check it in my network places right click on it thne go to proeprty then you see there wi fi network driver then enable it.if disable.
Then you can see search for available networks.
If not works then post here so i give you assistanse for router configuration.
Let me know if you need more assistanse.
Posted on Aug 31, 2009
govinda123
  • 2263 Answers
SOURCE: I have a linksys wrt160n wireless router,,
Is there any computer connected to the router ?
If not then connect the computer to the router. If you are connecting a wireless computer then disable the wireless connection on the computer. open the set up page of the router. change the wireless network name to something different that you never used before. change the standard channel to 11. save the settings. Try to connect to the wireless network. Check if you see the new network name ? If you see the new then try t connect and see if that works.
This router WRT160N has issues with the firmware.
Upgrade the firmware of the router. power cycle the router.
Click here for more information about router and network
Posted on Feb 28, 2010
I got a polaroid tablet pmid 705 series forgot pattern code how do i unlock it to change it to one i will remember
Once you forget the unlock codes, you're pretty much stuck. You're going to have to do a factory reset to get back into it.
Oct 25, 2013 | Linksys CISCO-LINKSYS ULTRA...
My linksys router doesnt have a default gateway and the reset buttton on the router doesnt work either
When you look between the Ethernet port and Power button, there should be a reset button there you should hold for 5 seconds. Of course if you do that, If you changed Network name and key that will be reset to the default settings, Also is wireless network showing when you pull up the Networks? You can leave user name blank, but default password is admin. Also email me with more info I will be glad to help
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml
Dec 26, 2011 | Linksys WRT54G3G Wireless Router...
The person who gave me Linksys WRVS4400N router decided to put a name and password on it that I cannot remove. I was wondering if there is any way to wipe it and restart it because the reset button on the...
When resetting a linksys router, you must hold in the reset button for 30sec before it resets to it's factory settings. Its is even recommened to hold it in for 40 sec to be shore. The factory default username and password is admin and on some older systems the there is only a password which is admin.
Sep 06, 2011 | Linksys WRVS4400N Wireless Router
Iomega harddrive is networked to my Linksys router and is not working properly. I'd like to know how to reset and start over.
You just have to reset the linksys router by using the reset button on the back. Push and hold the reset button for 30 seconds and this should reset the router. Access the router's setup page and set a static IP for the Iomega harddrive.
Hope this helps.
Jul 05, 2011 | Computers & Internet
When i plug in my Linksys wrt54gs my computer says that i have limited or no connectivity to the net?
Hi, before anything check if you have "set ip address automatically" on the network card properties. As a second step you could reset the router to it's factory settings pushing the "reset" button on the back of the router for about 5 seconds. I hope it works.
Jul 27, 2010 | Linksys Wireless-G WRT54G Router
I have a linksys router and my IP address is 192.168.1.1 how can I locate my passowrd/WEP?
The Linksys configuration URL is http://192.168.1.1 and if you cannot Login or remember the password then you can reset the router back to the factory defaults by -
Power up the Linksys and pressing and holding the pinhole reset button at the back of the Linksys for 30 secs. The router will restart.
Username Login = admin
Password = admin
You can now change the admin password and configure the wireless settings ie SSID, WPA or WPA2 encryption etc.
Don't forget to configure the wireless card in your computer with the router's wireless dettings so the computer can connect to the Linksys.
Apr 04, 2010 | Linksys Wireless-G Broadband Router
How can I put a code on my linksys?
Open Internet Explorer.
Type 'http://192.168.0.1' (or try 'http://192.168.1.1').
This will connect to the built-in web-server inside the Linksys router.
Click to run the 'Wireless Networking Setup Wizard',
and choose an SSID and choose a password-code.
Dec 29, 2009 | Linksys Wireless-G Broadband Router
Reseting without the button
192.168.1.1 default IP address unless you change it before....to verify the IP on your router ...right click on network icon or adapter icon ...select status...then DETAILS...the Default gateway is your routers IP
Apr 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
Computers & Internet Logo
222 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
