Question about Troy Bilt 5.5hp Self Propelled Mower
My Troy Bilt Snowblower wheels have locked up. Will not move forward or backward with the motor running or without it running. Help!
2 Suggested Answers
radar001
  • 1051 Answers
SOURCE: front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Posted on Mar 24, 2010
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have. Troy bilt snowblower, 3 yrs old and it just stopped moving forward or backward. The blower works and when I start the blower, the propulsion works a little bit then stops. I used yesterdAy and...
check the drive belt from engine to the transmission, sounds loose or even off. If belt and tension are ok check pulley for sheered key or loose coupling
Feb 09, 2013 | Garden
Troy-bilt tiller
The only way to roll around is to remove the pins on the axle and slide the wheels in and replace the pins. If this has never been done sometime its rather hard to do. Hope this will help
Apr 25, 2010 | Troy-Bilt Pony Garden Tiller
Front wheels lock up when pull mower backwards
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
My troy bilt won't go in neutral
The Junior tiller does not have a neutral selection. In order to free wheel the tiller you have to remove the pins that go thru the wheel rim hubs and then it will roll without starting it. Hopefully the rims are not rusted to the wheel shaft.
Frank
Mar 30, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
130 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
