Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
Saw runs fine for about 15 minutes,then the idle speeds up,then it dies,almost like it is flooding
  • 7,733 Answers
Do aclean or overhaul of all fuel components.Change the spark plug or the coil aka=spark plug cable.But if your saw in lees the 2 yrs you need to follow the starting guide in order to avoid flooding.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
My chainsaw, after runnig ok for 15 minutes, is now running sluggish. So, when i press the trigger the saw runs at normal speed for around 3 seconds then begins to die. I wait for a few seconds then the...
it sounds like a fuel issue. on my Stihl (390 )saw I had that same problem and I found that the fuel line inside the fuel tank was kinked and split and sucking air ( not fuel ). also check to make sure your gas oil mix is correct ( start fresh when in doubt ). it also can be a idle issue ( Fast idle or Slow idle ), but since you just had it serviced - I would look at the fuel line and fuel first. please let me know what you find and if that does or does not solve your problem,, there are a few more things to check. ( also - check to see if the air filter is clean and clear ,, brush it off if dirty ).
c...
Dec 29, 2010 | Stihl Garden
The saw starts and runs on fast idle but dies when you use the throttle? it,s a troybilt 18in saw
It sounds like it is flooding when you use the throttle, both are connected. Turn the idle back all the way until it dies, then try turning it a 1/4 turn the other direction.
Feb 19, 2010 | Poulan Pro Chain Saw 46cc 20"
Dies at Idle and decelration - won't start for 15
Hello. I bet your problem is one of these two things. 1: your timing is out. Making it run at such a low idle that it stalls itself out. 2: your truck is running too rich and flooding itself out. Just adjust theb timing a bit and lean the motor out a bit and you should be as good as new! Hope this helps!
Dec 08, 2009 | 1994 Chevrolet S-10 Blazer
15 horse mercury outboard
Clogged jets in the carb...clean out carb or rebuild carb.
Jul 28, 2009 | Boating
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
345 husqvarna chain saw will not run
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Jan 05, 2009 | Husqvarna Forest & Garden No.967012396 345...
Runs about thirty miles then acts like flooded or exhaust plugged
try checking your cadlist convert on your exhusted
Dec 26, 2008 | 1996 Dodge Caravan
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
194 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
