Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Do Whirlpool refrigerator ED25PW has a water filter & Where do you connect it?
  • 55 Answers
SOURCE: Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
  1. Check to see if water is flowing @ the water inlet valve @ the rear of the unit. You can remove it and clean if out-then put it back in service. You can purchase a new valve -- maybe @ home depot.
Posted on Aug 27, 2008
SOURCE: water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Posted on Oct 25, 2008
SOURCE: Change water filter on Whirlpool side by side Refrigerator
Jill, download the instructions here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202205958.pdf.
Posted on Jun 07, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
arikrom
  • 528 Answers
SOURCE: i have a model GD5PHA whirlpool refrigerator, no ice
the ice maker control the water timing.
if you have voltmeter you can check it on the water valve that go to the ice maker. but you can also disconnect the water from the valve and see if water are coming out.
99% its the ice maker that go bad.
Posted on Jan 20, 2010
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
I changed water filter on whirlpool refrigerator & now do not get water or ice. What did I do?
You have to put it properly. Other wise dispenser circuit signal will not pass through the filter compartment. When to install depend on the model. Put your model number at www.whirlpoolparts.ca website and see the diagrams.
Oct 12, 2014 | Whirlpool Refrigerators
From the water filter, where does the water tubing connect to?
Some have a connection behind kickplate at bottom front.
Oct 08, 2017 | Whirlpool Refrigerators
WHIRLPOOL W8RXEGMWQ TOP FREEZER FACTORY INSTALLED ICE MAKER, CAN I ADD A WATER FILTER OR WHERE DO I PUT WATER FILTER.
although this unit not equipt from factory with water filter,an add on can easily by installed. many different "in-line "water filter options are available, depending on installation, a filter can go either behind the refrigerator, or just passsed the initial water supply connection
Oct 27, 2013 | Whirlpool W8RXEGMW 17.5 cu. ft....
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
Water not coming out of fridge
First, I'm not a Whirlpool Tech.
*** Following is for information only.***
* Sputtering or no water from Ice machine and tap indicates a clog on the water line.
* Most of the newer (last 15 years) refrigerators come with a built in filter. It's probably clogged. Check the link below for changing out filter or type in "Whirlpool refrigerator water filter replacement'
* There could be ice blockage in water line if you have a very low temperature setting on your fridge. Most are set in the middle of the dial. If your set at maximum could then this setting may be too cold for the water line (it's coiled in the back of the refrigerator and may have frozen up.) Back the temperature a bid and give it a day or two to melt.
* The ice tray is missing a cover.
* Ice tray "Ice Full" lever is stuck in the Full position. Check if the Ice level (usually a stiff wire) is in the down or empty position. (some lock in the full position to turn off ice maker manually.)
* Check the water line to the refrigerator (or In-Line water filter) for water pressure. Turn off water supply. Remove water line from refrigerator and place end of line in empty bucket. Hold line down and have someone turn water back on then off after a few seconds (they may be too far to hear you yell "turn it off?!") If it just sputters then the line needs to be cleared. Check the needle valve for clogging. Close it off and re-open it several times. Otherwise this valve needs to be replaced.
* Follow the flow of water through each part: Supply line, supply valve, Water filter, Refrigerator inner filter, Tap point and Ice maker.
* Final, Check your warranty as any work (other than a MFR recommended customer water filter change out.) will void it. Call your vendor for service to be safe. (Have them do an annual maintenance while they are servicing your unit.)
Aloha, ukeboy57
Whirlpool link; https://www.bing.com/videos/search?q=whirlpool+refrigerator+water+filter&&view=detail&mid=B5D436DFC162C03FB4FAB5D436DFC162C03FB4FA&&FORM=VRDGAR
Feb 21, 2018 | Whirlpool Refrigerators
BROKEN SHELF CLIP IN FREEZER
Try to find as many numbers or letters after the ED25PW for example model ED25PWXAN01 There are about 30 versions of that refrigerator so start by entering the basic ED25PW into the model and search feature. And go to a link of your choice and click on the photo refrigeration shelves. There you can choose the parts from the display of the parts and components of shelves.
You can visit my link below. Let me know if I can help you further, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Jun 18, 2009 | Refrigerators
Water dispenser stopped working after changing filter
There is a built in system of valves on the filter connections that enable changing filters without turning off the water. IF the filters are not fully connected the valves wont open and there wont be any water flow. .
Feb 17, 2018 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
369 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
