Question about Kenmore Elite HE4 Electric Dryer
Getting hot but not drying. AF is the code that shows up
  • 2,418 Answers
AF means air flow. Pull the mach. out to access the rear and disconnect the hose, turn it on to dry and feel at the outlet for air flow, if you have good flow check the hose out to the vent for blockage. If you do not have good air flow, the fan is ban.
Posted on Nov 11, 2010
Keep getting "AF" code even after cleaning and washing lint trap and cleaning all hoses from back of unit all the way to out of house.
your description is common when there is a blockage , or blower not moving, I would take it apart again and reassemble to make sure everything is put together correctly.
Nov 30, 2015 | Dryers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
AF Code flashes briefly; Clothes don't dry - vent clear
Remove the back of the dryer and chek the lint filter area from the lint catching filter to the exhaust tube. There is a blockage in airflow even though you feel the air at the exhaust there still insn't enough air flow to allow the proper drying of the clothes. This symptom that you gave clothes being hot but not dry the only cause for this is improper air flow
Dave
Mar 31, 2010 | Dryers
AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 | Dryers
OVERHEATING, AF CODE..... Whirlpool Cabrio WED6200SW1
Mine is doing the same thing. Whirlpool still has it under warranty but says they won't replace it. They will only repair it. They have been out 5 times now and still not fixed. It will work one time and the clothes are scorched when I took them out. Do NOT BUY WHIRLPOOL. I think we should start a civil suit against Whirlpool for replacement of all of these washers.
Apr 11, 2009 | Dryers
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Jun 14, 2008 | Kenmore 67082 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
168 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
