Question about Watts Onan Portable Generator - 5000 , Model# 6500
Onan generator: Pro 6000e: engine runs, no electricity power generated; replaced battery with new one; had electrician attempt to restore collapsed field
  • Anonymous Mar 26, 2014
    Run but stops
  • 134 Answers
Are you getting any kind of voltage output at all?
Posted on Nov 11, 2010
  • Jon Ellis May 09, 2012
    I'm havin the same problem. I'm getting a little over 2 volts ac, and only .3 volts dc. IF you have and information it would be helpful.
  • markmcclinn
    markmcclinn Feb 11, 2013
    Lemons! Many are wired incorrectly from factory-thereis no support from retailer/mfg.
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
How does the wiring go from the own generator to its battery and then to electric panel
the ONAN generator only charges its own battery that it uses to start the machine,the generator itself is grounded with a 6 ft copper rod that is driven into the ground and secured to the ground strap of the generator,the wiring from the generator goes to a transfer switch that is installed ONLY BY A LICENSED ELECTRICIAN! DO NOT ATTEMPT THIS YOURSELF!,the switch is hooked up to your main electric line at the meter and to the breaker box,when the switch is used,it shuts off the main electricity from the company and opens the circuit to the generator only.here is the transfer switch,it can run everything up too 100 amps in your house or only 1 thing like your heat.
Apr 21, 2015 | Cars & Trucks
I have a 16.5 hp onan engine in a 1979 gravely tractor -with engine running why are my ignition points sparking
Ignition points open to collapse magnetic field in ignition coil to make spark. They have a condenser across the points to reduce the spark which comes because the current collapse also generates a back feed current in the now open circut in the primary windings. This is the spark that damages and wears out the points. Check with a competent Auto Electrician that the condenser (also called a Capacitator) is the right capacity for the coil being used.
Jul 20, 2014 | Garden
My Onan Marques Generator runs but not swap over to 120 volts
What do you mean won't swap over to 120Volts? are you referring to a transfer switch not switching over to generator?
Dec 17, 2012 | Onan Marquis RV Generator 7000 Watts Gas
Onan generator 2005 model hgjab-1038c rv generator will not keep batterys charged have to hook battery charger every time that generator is not running what should i check for this genator is in my 2005...
Go to the auto parts store and buy a "Battery Tender" solar powered, or get an electric trickle charger. Or install a battery disconnect for the period the unit is not in use; you can disconnect the battery.
HTH,
Mike...
Dec 02, 2009 | Watts Onan Portable Generator - 5000 ,...
Lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Jun 05, 2009 | Watts Onan Portable Generator - 5000 ,...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Onan 20K Generator runs constantly in stand by mode
Your remote start wires going into your transfer switch are closed, which means you transfer switch is the problem.
Feb 11, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
1,326 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
