Question about Canon Office Equipment & Supplies
COLOUR PRINTS HAVE VERTICAL LINES THROUGH MAINLY LARGE BLOCKS OF DARK OR BLACK AREAS - WHY?
  • 550 Answers
Maintainence tab of the printer software, clean up,
also ink levels may be low.
some versions of printer drivers have problems with large color areas, ensure you have the most current driver, for the unspecified printer. post back model details for some guru to be able to draw the correct answer
Posted on Jun 17, 2008
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Light or Faded Areas in Solid Color Prints
If the issue is occuring in the same place on all prints, try the imaging drum (can't remember if this printer even uses one) or the transfer belt/roller (not sure which it uses). If you phone Dell support, they should run you through troubleshooting and send you either of those parts free of charge if you are under warranty. If not, buy them anyways; they don't degrade over time (if kept in the dark) and can be saved for when the currently installed one runs out if you don't need it to fix this issue.
Nov 27, 2008 | Dell 3010cn Laser Printer
Ink gets carried over to subsequent sheets
More than likely your maintenance kit roller has been impacted with ink and is not applying enough lubricant to the drum. You can replace the maintenance kit and run cleaning procedures a couple of times to allow it to clean up.
Now the other issue is if you are using a third party ink stick. By that I mean non xerox brand ink sticks. I have seen those cause that problem more often than not.
Pull out the maintenance kit and see if the large roller, which should be a off white, is black.
Exacly what is happening is your maintenance kit puts a very thin film of silicon oil on the drum so that the ink does not adhere to the drum more than normal. When that roller becomes blackened, it isn't very effective and you get some of that residual imaging.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Severe banding
u better check the haftone test first,when printer starts to pict the paper,just let the printer to print paper,stop the paper before entering the fuser unit located back side,if the output is perfect,then it is the problem with the fuser assy,pls revert for further solution or query
Jul 19, 2008 | HP LaserJet 2500L Printer
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Vertical streaks
The toner forms small lumps and get stuck on the doctor blade of the cartridge. Where there are the lumps it blocks the toner from getting on the roller. Removing the doctor blade and cleaning it with a soft cloth and alcohol can solve your problem.
Send me a mail at ecoworld@myt.mu if you need further help in doing it.
Sep 11, 2007 | Lexmark C500n Laser Printer
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
220 people viewed this question
old marine
old marine
