Question about Garden
The off on switch it not working not geting fire can i bypass it some how
    Brigadier General:
  • 4,088 Answers
The only way to stop it after you got rid of the switch would be to choke the engine. Assuming that this is a recent model saw, it should have an ignition module that has the entire ignition function contained within the module. Remove the left side engine cover to expose the flywheel and ignition module. The ignition switch is attached at the end of the module coil, not the metal poles. Just remove the wire connection which eliminates the switch function. Reassemble the case and check for spark--it should be blue and snappy with a fresh plug gapped at 0.020". If ok, I would suggest repairing or replacing the switch. If still no spark, then likely the module itself has failed. Use a thin business card to set the pole gap over the flywheel magnets. Hope this helps!
Posted on Nov 11, 2010
My 2004 montecarlo is not firing or geting fuel but is cranking
check fuses relays etc then check the fuel pump and ecu unit
Feb 17, 2013 | Cars & Trucks
I got a 917259570 Model# Craftsman will not fire at the plugs and the Coil is new, getting power to the Coil and will not fire.
Make sure you have the air gao on your magneto set correctly, check/test your plugs.
All the safety switches are working correctly? Have your bypassed them?
May 26, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2.3 liter dual coil pack fuel injected wiring diagram to fuel pump;relay;inertia switch. geting no fire to igntion switch and when i rewired got fire to switch but not fuels etc.?
Look out under hood on drivers side for a power relay these are known to blow.If its blown it will not allow any power to the ignition system at all.It should be in a fuse panel under the hood.
Aug 10, 2011 | 1992 Ford Ranger
Everthing kicks on just fine but burners will not fire or fire and turn off. Wired around the high level sensor and it worked fine. The weekend beofre it worked fine. Seems odd possibly the high level...
Hi, I will keep this short as you have solved this already. If you have bypassed a sensor, or any kind of safety switch to get heat, this is the faulty part. If it is working fine bypassed, you need to replace it as it is faulty. You are jumping across the contacts, so pick up a new one. Please don't leave it bypassed for long, just until you get a new one. Good luck to you, and good job!
Shastalaker7
A/C, & Heating Contractor
Please don't forget to rate me!
Nov 19, 2010 | Dayton Heating & Cooling
I have a Craftsman Riding mower 17 HP, 42"cut. It runs for ~30 minutes then shuts off like it's out of gas, but it's not. Won't restart for ~30 min. Can anyone help
check for fire to the plug after it dies....if there is no fire then its possible that the coil is breaking down and needs to be replaced.
Nov 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not start. Can jump accross the selinoid and
I assume that you are jumping the solenoid in order to bypass an ignition switch that is no longer operating?
If so, did you have the key turned to the run position?
You should not need to bypass any safety switches, just be sure that everything is in the normal starting position. (deck disengaged, in neutral, etc.)
Either way, it sounds like you have a bad ignition switch, or faulty wiring between the ignition switch and the solenoid.
Jul 30, 2009 | Garden
Power windows 93 chevy pickup
hi ken, by the way you describe it i would say the switch on the drivers door needs replacing hope this helps
Mar 19, 2009 | 1993 Chevrolet K1500
How to bypass door switch
you dont want to by-pass the switch ,,,, its on there for safety and if it is by-passed it can cause problems with dryer or worse could start a fire.
Oct 24, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Won't fire
It may also be the high temp switches under the 2" inlet/outlet header. The 150 degree high-limit switch sits horizontal and corrosion happens often there. But be careful removing as if the header is corroded and the switch is also, water will flow out , so be ready to bypass the heater. You will have to replace the header. Try to jumpe that switch out and I'll bet the heater fires up.
Jul 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
