Question about Dishwashers
MacMarkus, I just got parts for the dishwasher. I put the circ pump in and no water enters the dishwasher. I also see that I didn't put a plastic cover on one of the leads, so I need to pull the dishwasher to do that. How do I know if I've installed the pump correctly?
  • cdracos Nov 13, 2010
    Well, the service manual for Asko 1385 isn't available. The only place I could find it had a "Live Anti-Virus 2010" that took over my computer for 18 hours. Do you have an Asko 1385 service manual in .pdf?
  • 12,061 Answers
Hi look to have even an even chance of repair one simply must get a service manual for the unit you are working on. Simply Google the exact make and model, plus the words...... "Your-make-and-model" service manual pdf download (enter)
If there is NO water coming in, then it can only be The Inlet solenoid, either NOT being commanded to work, or it is stuck, remove, and soak in penetrating oil for a while, clean and replace to try again.
The pump really can only go in one way.. but again, you DO need the manual to check.
Posted on Nov 12, 2010
Bosch diswasher model no.She3ar72uc/22! It gives me a code E-24!!! How can I get rid of that code to get my dishwasher to work?
theres either a problem with the drain pump or the re-circ pump is drawing too much current, if the error appears at the start before it fills with water and there is no water left inside the unit it is the re-circ pump, if its not draining water its a blockage or a faulty drain pump
Jan 10, 2017 | Bosch Dishwashers
Tip
L.G E1 Error / Whistling Sound In this Tip I will show you how to fix it. This...
In this Tip I will show you how to fix it. This error is not to be confused with the 1E error, as this means something completely different.
TOOLS REQUIRED:
- Circulation Pump (P/N: 5859DD9001A) * I will use "Circ. Pump" when referring to it. Get it from your nearest appliance spare shop.
- Screw Driver (Star/Phillips)
- Towel
- Pointed Object (Flat Screwdriver is best)
- Patience
SYMPTOM:
E1 is showing on the LED Panel. In most cases this is accompanied with a whirring/whistling sound from the Dishwasher. This solution will also solve motor noises as described above.
REASON:
There is an excessive or low amount of RPM picked up on the Circ. Motor Impellers during wash cycle. The reason for this is a water leakage on the Circ. Motor. The seal basically got worn, and water came through to the motor shaft leading to the bearings, thus the whistling sound (if any):
The only way to repair this error correctly is to replace the Circ. Pump.
CHECKS YOU HAVE TO PERFORM BEFORE DOING ANYTHING:
Firstly check for any leakages on the hoses or plastic covers, especially the hoses & covers directly connected to the Circulation Pump, any leakages will also trigger this error code. Check the below mentioned "Accessing the Circulation pump" instructions, for easy access to the Circulation Motor.
THE REPAIR PROCEDURE
STEP 1 (Accessing the Circulation Motor)
Firstly, remove the Inlet hose from the unit, and position it in an area where you would be able to lay it on its side. Then drain all water from the dishwasher, this can be done by placing the Drainage hose on the floor (either into a low bucket or out the back door).
Then remove the Top Table (The "roof" of the dishwasher), this can be done by removing 2 to 4 screws at the back -this may vary from model to model:
Remove the Right hand Panel, you will need to open the door for the front screws - See attached pictures:
You then need to close the door, and remove the bottom cover panel, there will be 2 more screws here:
You can now remove the Right hand Panel and you should see the following:
Now, put the towel on the Left side of the machine, you are going to tilt the dishwasher to its side, and water will likely leak out on that side.
Lift up the insulation material, and then lean the dishwasher back so that it is laying on the Left Panel:
Again some screws would need to be removed from the Base Cover, see pictures:
STEP 2 (Removing the Circ. Motor)
Now you have to stretch the Base Cover to allow yourself some more space to remove the Circulation Pump. To do this, insert your flat end into the Jimmy Space (Shown on the previous picture), use this in a crowbar like action, to give you some extra space - Beware not to break the plastic!
Remove the Screw mounting the Circulation Pump to the Base Cover:
Disconnect the Power cord to the Circulation Pump:
Then remove the Mounting piece, and twist and pull out the Circulation Pump from its nesting area, be careful not to break fittings or move other components (Especially the Sump) while pulling the Circulation Pump free:
The sump as seen above must not be showing more than 2 mm of silver lining, if it does, it means the sump has shifted too much, and leakages is almost a certainty. YOU DO NOT WANT THIS TO HAPPEN :-)
With the Circ. pump removed, you can now easily insert a new one, and use the reverse of my instructions to finish the job.
Just another quick note:
Sometimes the mounting supplied is different than the one that was in the machine, always fit the new one.
That is it! Re-attach the hoses and water, connect the dishwasher to power. Test it and viola, the E1 error is no more, and any whistling sound that may have been there is now a distant memory.
PLEASE BE AWARE:
Even though this is accomplish-able by yourself, no person would disagree that an experienced and qualified technician will be able to do it more accurately and without further damages to your appliance.
Experience is what you got by not having it when you need it. ~Author Unknown
Thanks for reading my Tip.
on Jul 06, 2011 | Dishwashers
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart Dishwashers
Hobart LXiH error E4 AND a part makes noise when off
test this steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Bosch shu43c02uc
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 | Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
No water in the dishwasher Bosch SHX43M02-48. We turned of the water and forgot to turn it back on and ran the dishwasher. Now the it will not let water in?
Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
Mar 05, 2010 | Bosch Dishwashers
Circ pump runs, but does not pump
Oppen the centre orifice , remove cover , remove impeller , clean debri and change impeler with new one, Vitally
May 13, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
Owen Barnes
