Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
After running and shutting off will not restart without a lengthy cool down period. It then starts right up and runs fine.
  • lynn_porth Nov 14, 2010
    Husquavarna Model 125bt Leaf blower
    I fill up with gas and proper oil mixture. I cold crank and it fires right up and runs fine. I operate it until it runs out of gas and it shuts down. I fill up immediately and try to crank. It has to cool down for at least an hour before it cranks again.
  • 2,427 Answers
Is it gas powered ?? If so try changing the oil..
Posted on Nov 12, 2010
Why does desktop pc running win xp pro, when choosing "start/shutdown/restart", fail to restart, but if choosing "start/shut down/shut down" it works fine?
http://superuser.com/questions/14163/when-windows-xp-wont-restart-how-to-diagnose-how-to-shutdown-without-power-c
May 23, 2014 | Computers & Internet
I have a Kenmore Dryer Mod#110 62722101. It will run about 10 minutes and shut off, after a cool down period it will restart but only run about 10 mins. Heats, fine, tumbles fine. A few days before this...
If it runs after a cool down period, then the high temperature limit is part of the cause. What is causing the high temperature limit to overheat is next.
Strong stream of air should be felt coming out the exhaust, make sure this exhaust air works or the burner part will overheat and cut out the flame/burner on hight temp safety.
With good exhaust air varified, the drying air operating temperature sensor needs to be checked, this cuts power to the burner. The sensor must open electricaly when satisified on temperature and should be properly mounted for proper sensing of temperature.
Bottom line: Check the hot air and its control
Jun 04, 2017 | Dryers
Have a GF500 Monitor Propane Heater - keeps shutting down. Once it reaches the set termperature the burner begins to back off, and then the "burner status" buttons start flashing and the unit...
This sounds like your thermo-couple has a short, or is defective, it is supposed to kick off at the set temperature, then turn the burner back on after it cools down, a temperature probe is usually coonected o this as well, either one of which could be defective. Try to replace those parts and see if that does the trick.
Jan 17, 2011 | Heating & Cooling
Curious as to why my InFoucus LP860 has blue in the corner and also runs down the side of the image... its a consitint....connected to a source or not.
This is heat damage to the lcd panels due to the projector not being shut down properly. When the unit has been on for any lengthy period and it is shut off using the on/off switch on the rear of the unit, this shuts the whole thing down, fans and everything. If it is shut off using the on/off buttons on the remote or on top, the fans keep running until the unit is cooled and then powers itself completely off. The damage is only fixable by replacing the light engine and if not under warranty is very expensive.
Oct 08, 2010 | InFocus LP860 Multimedia Projector
92 ford focus runs fine but won't start after
If car is parked for 45min running will it restart?
Most likely you have a fuel pump getting hot & shutting down cools off & then will restart. The fuel pump relay could also do this.
Jul 14, 2010 | 1992 Ford Tempo
1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
Feb 01, 2009 | 1991 Jeep Cherokee Briarwood
Shutdown after graphic intensive use
It would seem in my opinion from the information you gave, that your processor of graphics processor is overheating and shutting down the laptop. Possible the cooling fan is not operating correctly. Do you hear your cooling fan running at all?
Hope that helps.
Dec 17, 2008 | Global Marketing Partners Smart Restart By...
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
59 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
