Question about Kenmore Refrigerators
The ice dispenser is not working in the door on my Kenmore Refrigerator, Model 57577791. It makes ice but won't dispense it. It does dispense water. How do I get the the selnoid switch to replace it? How do I take the front face plate off of the dispenser unit on the door?
  • daern Nov 12, 2010
    Thanks, I'll give it a try. I thnik this one has a plastic face panel it doesn't appear to have any vinyl.
    Their are no screws on the back side that are visible and that panel is full height of the door.
  • 3,083 Answers
On most Kenmore and Whirlpool units, you have to peel the vinyl off the front to get to certain parts. I couldn't bring up anything on this model, but on some you access it from the back.
You should call or visit a Sear's Repair Center, and chances are that some tech can explain the process, and possibly order you a part at the same, diagnostic time.
Also, check your motor and the wiring if the solenoid is good.
Good luck, and hope this helps.
Posted on Nov 12, 2010
  • 2,299 Answers
This could be a couple of different things causing the dispenser to not dispense ice. It could be the switch, like you said. But you will want to check the actual motor that pushes the ice out. Check to make sure that you are getting power to the motor while trying to dispense ice. This motor going bad is more common than the switch in the door.
We have a Kenmore Model 57577791 refrigerator. It's almost 13 years old. For about 6 months, it hasn't been dispensing water. It makes ice, but constantly freezes up right where the ice goes out...
Water is only in the line, theres no tank so one cycle will get rid of any old water, then you can just throw those ice cubes away. The way to fix the problem is to replace the solenoid fill valve on the back bottom corner of the refrigerator, Thats the thing the water hose connects to. It has a slow leak that is causing the ice to build up in the tube. Good luck.
May 29, 2011 | Refrigerators
Notting on the door works. No water, ice, ligh Model 363.9534710
Check the wire connections under the hinge cap on top of the freezer door.
Jan 15, 2010 | Kenmore Refrigerators
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
61 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
