Question about Canon PowerShot A620 Digital Camera
On my 2nd 4gb card each time i put it in get memory card error card locked- i know about the slot on side of card to unlock-i had a 512 sd in before worked great-is card compatible san disc 4gbhc thanks for any help.
    Guru:
  • 2,178 Answers
Check and see if it's a 4.0 GB SD(HC) card. Some cameras cannot accept them. Check you camera's user manual for compatible cards.
Posted on Nov 11, 2010
Have a 4Gb memory card but when I put it in SD slot to take pictures, it always indicates CARD ERROR even whe the card is unlocked.
From what I see of the specifications for the NV-GS25, it uses SD cards. Your 4GB card is actually an SDHC card, which is electronically incompatible and will not work in devices not designed for SDHC cards. You need to use SD cards, 2GB and smaller.
Dec 15, 2012 | Panasonic NV-GS25 Mini DV Digital...
What's your problem?i put a 4gb memory card in my canon SD 200 and it says error why
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Mar 05, 2012 | Canon PowerShot SD200 / IXUS 30 Digital...
I got a new 4gb sd memcard for my 2005 canon ixus 50, screen shows " memory card error" "card locked". tried switch on card as u suggested, no diff.
The IXUS 50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Canon Cameras
Vivitar 5399 not reading memory card. Originally had a 4GB card and that worked fine, then all of a sudden the camera wouldn't read the memory card. Card is fine in other cameras. Just switched to a...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 28, 2010 | Vivitar Vivacam 5399 Digital Camera
My memory stick is write protective and i can`t solve it. how can i solve.
Hello
Kind regards
Andrea
Aug 20, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Is canon digital IXUS 55 compatible with 4gb SDHC memory card message reads card locked or error
The maximum amount the Canon sd450 can support is a 2gb card, anything more and you 'll just get error problems.
Aug 16, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Microsd memory card is locked
there is switch lock and unlock on the edge of memory card .
Jul 23, 2010 | SanDisk 2GB microSD Memory Card
Why does it tell me memory card error with a new 4gb card
Hello
Kind regards
Andrea
Apr 22, 2010 | Vivitar ViviCam 8300s Digital Camera
My sd card is not recognized in my computer and camera
If neither your computer nor your camera will recognize your card then it is safe to say that there is an issue with the card. You may either have bad contacts or an internal issue, but since your camera states it is locked when you say it is unlocked that would normally signify an internal issue. If you still have a warranty on the card I would suggest you take it back to the place it was purchased from.
Feb 01, 2010 | Generic Memory PCI USB and Firewire Combo...
The Kingston 4GB SD memory card I was using in my G7 camera gave me an error message "Memory Card Error" and "Memory Card Locked". It was working fine, then did not. How can I solve this problem and get my...
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 23, 2009 | Canon PowerShot G7 Digital Camera
Canon PowerShot A620 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
