Question about LG LRFD25850 Stainless Steel French Door Refrigerator
The water tank in the door leaks when I dispense water....it only leaks when water is being dispensed....I removed the cover & can see water shoot out of a small pin hole in the bottom of the tank....I need the part number for the tank and to know if this is a simple repair or not. Model number on my fridge is LFRD25850ST. THanks. Jeff
  • jeffnolte Nov 12, 2010
    epoxy a good choice for adhesive?? If I have to replace the tank, are there any special tools required to remove/replace the fittings?
  • 2,973 Answers
Jeff,
I can make it simple without any part numbers. If it is a pin hole as you say then dry up the surface, empty the water tank, allow it to dry up and put a drop of Super glue or quickfix or some such adhesive. let it dry for a few hours and then use it as new.
Posted on Nov 12, 2010
  • Rinoo Kumari Nov 12, 2010
    That is a good choice you have. And for such a small hole that can be plugged why should you want to replace complete tank. Minor issue. You do not need any special tools except the usual spanners and pliers etc.
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
My whirpool sise by side rrfrigerator leaks d\from
there should be two small holes on each side of the dispensor cover
push a small nail in to those holes and pull forward
it will snap back in when your donr
Oct 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leak from hose that connects MT641 Heating Tank to Dispenser
It may be a push n lock. If you can send a pic of your phone vam, send one and we can see what's needed. Co7196@yahoo.com. If its a push n lock, While pushing on the line push in the smaller inner sleeve and pull on the line. Make sure there is not pressure in the line.
Sep 22, 2009 | Mountain Plumbing Mountain The "Little...
Water is leaking out of the machine Im not quite sure where from.I guess pouring out would describe it better .It`s not coming from the door.
leaks are usually from valve /dispenser area on top left or from door boot. to check valves open top cover by removing 2 or 3 torx/ 1/4' screws at rear and slide back. check underside of dispenser for cracks, check rubber hose connecting valves to dispenser.
to open front and check around boot, remove top cover, remove screws beside dispenser opening (remove drawer) snap control console off starting at dispenser side. On older non teardrop front disconnect and remove interface cables from ccu at rear (ribbon cable in clips on right side. On new teardrop models remove teardrop by unsnapping at top then work down carefully, then unclip console starting at left, disco cables at right side of interface. remove lower kick panel with 3 screws on bottom. then remove 2 front panel screws. remove 2 door lock asm screws and spring clip around boot, then 2 front panel top screws. panel comes right off, carefull of boot. door lock stays behind.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from under machine
This could be a door boot(loose or hole), it could be coming from dispenser area, going down to bottom of door, water pump, hose damage.
Oct 22, 2008 | Whirlpool Washing Machines
Water leaking from dispenser into refigerator/French door bottom freezer
IT IS PROBERLY THE HOLDING TANK / TUBES LEAKING TAKE LOWER CRISPERS OUT AND CHECK THERE ITS BEHIND THEM
Aug 26, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LRFD25850 Stainless Steel French Door Refrigerator Logo
77 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
