How to either turn off or disable "safe mode" at windows xp
  • 2,296 Answers
How do I disable Safe Mode? (NT, 2000, XP)
Windows NT, 2000 and XP do not have any easy way to disable Safe Mode. However, there is a way to 'break' safe mode temporarily.
Doing this is not recommended. Proceed at your own risk!
Click on the Start Button
Select Run
Type in "regedit" and hit OK
Expand the left hand side to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\SafeBoot
Under SafeBoot, you should now see Minimal and Network. Click on them and hit F2 to rename them to "Minimal-" and "Network-", respectively.
This should cause Windows to crash the next time it is booted into Safe Mode.
Posted on Nov 12, 2010
2 Suggested Answers
  • 186 Answers
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Posted on Jun 23, 2009
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Tip
How to Bypass Windows XP Password in Safe Mode?
As a special diagnostic operating mode of Windows, safe mode which starts Windows with a limited set of files and drivers helps you to diagnose and troubleshoot various computer problems. Whenever your computer crashes or a spyware or virus affects your PC, you can enter safe mode to fix these problems. So when you want to <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">bypass Windows XP password</a>.<br /><br />There are 3 safe mode options, here only shows you detailed instructions on <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">how to bypass windows XP password</a> by safe mode with command prompt, which will starts Windows in safe mode with a command prompt window instead of the usual Windows interface. Before proceeding the following steps, please make sure that you never set a password for the built-in administrator account on your Windows XP machine or you can remember password of a Windows account with administrative privileges.<br /><br />Step 1. Turn on your computer.<br /><br />Step 2. Repeatedly tap F8 key as the computer is booting. It will bring up the "Windows Advanced Options Menu" as shown below.<br /><br /><img src="yaoch.png" /><br /><br />Step 3. Use your arrow keys to select "Safe Mode with Command Prompt" and press Enter.<br /><br />Step 4. Windows will load files until you see a logon screen similar screen with all your account user names displayed. Enter password for your administrator account to get in safe mode.<br /><br />Step 5. You'll see Windows command prompt after entering safe mode.<br /><br />Step 6. Enter "net user" on the command prompt, and press Enter. It will list all the user names of your Windows accounts. Here we assume that there is a user name of "Jack" in the list and you want to bypass the "Jack" account password.<br /><br />Step 7. Enter "net user Jack 123456" on command prompt and press Enter. This command line means that you want to reset the lost "Jack" account password to "123456". When it takes effect, you'll be able to logon the Jack account with the new password of "123456".<br /><br /><img src="yaoch_0.png" /><br /><br />Step 8. Now all the operations compete and you can exit safe mode by restarting computer.<br /><br />Please note this method will not work for you if you cannot enter safe mode with an administrator account. Under this circumstance, what should you do next? Well, don't feel impressed. Windows password recovery solutions aren't limited to this. <a href="http://www.anypasswordrecovery.com/" style="font-weight: bold;">Rekeysoft Windows Password Recovery</a> is another good choice. It only takes you 4 steps to bypass Windows XP password in less than 5 minutes.<br /><br />Step 1. Download and install Windows Password Recovery.<br /><br />Step 2. Burn a bootable Windows password reset CD/DVD/USB flash drive.<br /><br />Step 3. Insert the CD/DVD/USB flash drive in the locked computer and set BIOS of the computer to boot from CD/DVD/USB flash drive.<br /><br />Step 4: <a href="http://www.anypasswordrecovery.com/reset-windows-xp-password.html" style="font-weight: bold;">Reset Windows XP password</a> under Win PE with a few clicks.<br /><br />Of course, if you had created a password reset disk after creating a Windows password, you can easily use this disk to change the lost login password to a new one with ease. It will save you from a lot of troubles when forgot login password to your Windows XP computer.
on Apr 19, 2011 | Computers & Internet
Disable safe mode
Which operating system and do you have Norton antivirus ???
Turn Off Safe Mode
You rebooted your PC at least 10 times now, and still it refuses to start in anything other than Safe Mode.
Your many attempts to perform a system restore have yet to be victorious. It just will not boot up normally.
According to Microsoft, if you have Norton Antivirus 2001 installed on your computer, it is the root of the problem. Microsoft suggests you disable it.
Restart your computer. Let it load completely in Safe Mode.
Press "Run" on your Start menu.
Once you see the Open box, enter into the provided text box: misconfig.
Then press "Enter" or Select "OK."
Select on the new dialog box that has appeared "Selective Startup."
Select "NAVAP.VxD" on the Static VxD tab.
Remove the check in the check box you now see.
Select "OK."
Remove the check in the check box next to Norton Auto Protect.
Select "OK."
Reboot your system and it will be in Normal Mode.
Turn Off Safe Mode in Windows XP
The purpose of booting your computer in safe mode is to resolve issues.
Only your basic, most dire drivers and programs will run to block viruses and surreptitious software from executing on your system.
But once the issue is resolved, you need to get back to the standard Windows mode. In order to turn off safe mode in Windows XP, you must go through the same steps that you took to turn it on.
Reboot your Windows system.
Press the "F8" key several times as soon as you see the first Windows XP logo appear on your screen as the computer is booting.
This will bring up a black screen that displays the "Windows Advanced Options Menu."
Press the down arrow button on your keyboard to scroll down the list.
Select "Start Windows Normally" and then hit "Enter."
Allow the system to boot.
Enter your Windows XP user password (if you set one) and log in as usual.
Nov 14, 2013 | Computers & Internet
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
We have a Gateway Laptop running on Vista. Turned it on this morning and got the "blue screen of death" that said it had a Fatal Error KnownDLL 000021a and a bunch of other numbers. We read that...
Just press and hold F8 on startup (before the Windows logo appears). You should get the screen with the title Advanced Boot Options and the following menu. (which I get on my Gateway NV5915h)
Choose Advanced Options for: Vista (Windows 7 on my Gateway NV5915h)
(Use the arrow keys to highlight your choice.)
Repair Your Computer
Safe Mode
Enable Boot Logging
Debugging Mode
Description: View a list of system recovery tools you can use to repair
startup problems, run diagnostics, or restore your system.
ENTER=Choose ESC=Cancel
Mar 18, 2011 | Computers & Internet
I' can't login ni my system. The computer get started but just to the point when the windows say "WELCOME". Now I must login to the system to start working with computer.I can just turn off the...
power on the system and as soon as you press the power button keep tapping the F8 key .this should take you to windows advanced option menu.select safe mode and press enter.this should take you to the safe mode where minimum and basic services are running.then
press start>run>type msconfig>this should pull up a window
the last tab would be startup.click on start up and select disable all, click on ok and restart the system.if this time system goes to normal windows this means some program is causing the issue at the time of start up.
if it doesn't go to windows then go safe mode and follow the same steps and this time click on services.click on hide all microsoft services and disable the rest.and reboot.
if this goes to normal windows in any of above 2 steps this means some service or some program is causing the issue.and you can go back to safe mode and enable all and eliminate one by one.this way you will come to know which program is causing issue.
IF THIS DOESN'T EVEN GO TO SAFE MODE THEN
boot from windows Cd and try and repair with recovery console
Nov 26, 2010 | Microsoft Windows XP Professional
I install brico pack(themes or xp) after some days i download servicepack 3 from internet and istall that to my pc. install sucessfully, but after restart windows diint get in i just see black screen ony.....
Follow the steps given below to resolve the issue.
1. F8 at system startup.
2. Boot to safe mode with command prompt.
3. Perform a system restore.
For instructions on how to perform a system restore from Safe Mode with Command Prompt use the link given below: http://support.microsoft.com/default.aspx?scid=kb;en-us;304449
If this fails do a system restore from Recovery console.
Jan 22, 2009 | Microsoft Windows Vista Ultimate Edition
Forgot password
Reboot the computer. Press and hold the f8 button. Select safe mode from the menu. You should be able to see the admin login. Then you can make the changes.
Nov 22, 2008 | Microsoft Windows XP Professional With...
Safe mode
because of virus you start windows in safe mode an try booting if it work in safe mode > go to run > type= msconfig > disable all in startup, reboot windows see if it works if not please reinstall windows xp.....
May 07, 2008 | Toshiba P205-S6267 Notebook
Laptop Startup
hi dear
oh so sorry to hear that
this methode for windows Xp
and let try this
Microsoft Windows Vista users Tip: If you are running Safe Mode because you cannot get into Windows you may want to first try loading the last known good configuration. Additional information about this mode can be found on document CH000626
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Debugging Mode
Disable Driver Signature Enforcment
ok
cropp
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
