Question about Ovens
We have a maytag MER 5875 RCW Oven. how can we change from fahrenheit to celsius ? we do not find the manual anymore. thanks for help
  • 8,197 Answers
Welcome to FixYa!
Changing Temp °F/°C
1, The factory default setting for temperature is Fahrenheit,
2, To change the setting, press and hold the CANCEL and Bake
pads at the same time for three seconds,
3, A single beep will sound and the current setting will be
displayed (°F or °C), (if no change is made, the range will
return to the existing setting after 30 seconds,]
4, To change the setting, press the More+ or Less- pad, Press
again to return to existing setting, Wait five seconds and the
setting will be complete,
Good Luck Also If you would like the manual please ask I will send it to you
Posted on Nov 11, 2010
180 fahrenheit = ? celsius
82.22222 or you could use the formula below:
(°F - 32) x 5/9 = °C
To convert (°C) Celsius to (°F) Fahrenheit use the formula below:
°C x 9/5 + 32 = °F
Mar 06, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
How do I warm up the oven to 200 degree celcius
Most American made ovens are going to be in Fahrenheit and 200 degrees Celsius would be just under 400 degrees in Fahrenheit. Hope this helps!
Feb 13, 2015 | Ovens
What dose 180 degrees Celsius Fahrenheit mean so I can bake
Hi Nancy,
180 degrees Celcius is about 360 degrees Fahrenheit.
Jan 29, 2014 | GE JKP30WMWW 27" Built-in Single Electric...
How do you change the key pad from celcius to ferenhite on my whirlpool acubake oven
Look for the button marked "Precise Clean" in the upper left corner of the control panel.
Press and hold this button for five seconds until the display reads "Temperature Unit Celsius.
Release the button and push it again for another five seconds until the display shows "Temperature Unit Fahrenheit."
Push the "Off/Cancel" button to lock in the Fahrenheit setting.
Jul 10, 2011 | Whirlpool SB160PEE Gas Single Oven
We too ended up with melted reynolds wrap standard aluminum foil lined and then melted to the bottom of our oven. The smell was terrible. The thing was, we didn't know it was the aluminum foil until we had...
It is very difficult to melt Teflon; 326.8 degrees Celsius or 623.24 degrees Fahrenheit, hotter than most ovens! Rapeseed cooking oil will have long before caught fire.
Teflon is not used on oven floors, walls or racks.
The melting temperature of aluminium foil is 660 degrees Celsius (1,220 degrees Fahrenheit) at standard pressure, so it won't melt with temperatures encountered in a standard household oven!
Toxic fumes from the Teflon chemical released from pots and pans at high temperatures may kill pet birds and cause people to develop flu-like symptoms (called "Teflon Flu" or, as scientists describe it, "Polymer fume fever").
Oct 15, 2017 | Ovens
Is the temperature in celsius or farenheit
If it is Celsius it would only go up to 250, Fahrenheit would be marked to about 500. You can download a user manual here.
You can do conversions between celsius and Fahrenheit here.
Oct 07, 2010 | Baumatic Ovens
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
Changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Oct 19, 2008 | Whirlpool Ovens
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
