LG WM2501HVA - LG washing machines Why does wash load take so long. My Old washer took half the time?
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
I have a front loading machine also and am not willing to have to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Posted on Aug 23, 2007
  • 62 Answers
SOURCE: Step by step pictures showing How to Dismantle Washing Machine for maintenance?
get the full model and s/n from machine and search on that also try LG...the search may take you there anyway
Posted on Jan 03, 2008
IFIXALL
  • 868 Answers
SOURCE: Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
Posted on May 20, 2008
gdmisp
  • 66 Answers
SOURCE: washing machine
BELT NEEDS REPLACED OUR THE DIREC DRIVE NEEDS U JOINT.
Posted on Jul 03, 2008
MNTECH
  • 1543 Answers
SOURCE: Lg Tromm washing machine drum will not turn
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Mar 01, 2009
8 YEAR OLD LG FRONT LOAD WASHER WONT SPIN OR DRAIN
If the washer won't spin the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
Aug 29, 2014 | LG WM1814CW Front Load Washer
My LG Front Load model WM2501HVA will not turn on and on last cycle was making fast paced clicking noises during spin cycle, what could the problem be?
see the possibles causes:
see the diagrams. God bless you
No power
test the fuse blown + c.breaker trip
Lid switch
test the lid switch for continuity with VOM
spin: see the diagram
May 16, 2012 | LG WM2501H Front Load Stacked Washer/...
Lg washer wm2501HVA light stays on
why my lllLG washer WM2501hva light stay on ????
Jan 29, 2012 | Washing Machines
I just bought this washing machine a week ago,everything seems to be fine but it takes an hour to wash one load of clothes,can I adjust the time to half an hour(my old washing machine only takes 30...
The newer washers are much more gentle on your clothing, but they also take their time to do the job...
Yes, it can be a pain to have it take so long but your clothing will love you for it and will stay nice for you longer...you will also be using less water...
Not much you can do about it as the engineers that know all are the ones that program these things...
heatman101
Jan 21, 2011 | LG WM2010C Front Load Stacked Washer /...
Smelly Clothes After Washing
First be sure no rodent has crawled in and died inside the washer aside from that run a half cup os fabreeze thre the system to see if that helps. Also have someone check that the pee trap that the dran is connected to is not backed up.
Aug 06, 2009 | LG WM2277H Stainless Steel Front Load...
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
