Question about GE 25 in. GSC3200Z Free-standing Dishwasher
I have a ge portable dishwasher and it will not drain the water at all on any cycle
catriver
  • 878 Answers
SOURCE: Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Posted on Jan 27, 2007
Catriver: The dishwasher model is gsd5920do1bb. I probably posted the original problem in the wrong place. Does a similar fix apply? Sorry about the confusion. Greg
Posted on Jan 30, 2007
  • 641 Answers
SOURCE: Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
My portable dishwasher wont drain all the way. it has water that comes out but not all
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Aug 23, 2010 | GE 24-7/8" Convertible Portable Dishwasher...
Dishwasher runs through full cycle but will not drain
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
heatman101
Apr 16, 2010 | GE 25 in. GSC3200GWW Free-standing...
Water does not drain from GE dishwasher.
Remove the drain hose from under the sink to verify that there is no clog. If the dishwasher runs in the "cleaning" cycle, but won't drain, you either have a clog or a bad solenoid. All the solenoid does is opens a little door to change from cleaning cycle to drain cycle. This part is VERY EASY to change. Definitely a project for DIY. The part runs around $60 from a parts place. Check ebay if you do not need it immediately and you can save abt $30.
Aug 16, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Profile PDW8280J10SS: Water won't drain. I
Can you get the water to drain at all in any cycle? If you can, then its possibly the control module .
If you can't get it to drain in other cycles or when you cancel the cycle, then its a possible clog in the drain outlet hose, drain solenoid, or screens.
Here is a good detailed link to check out that explains about it:
http://www.applianceaid.com/gedishdrain.html
Heres another link about general dishwasher draining issues:
http://www.applianceaid.com/drain_wash.html#drain
Apr 16, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 25 in. GSC3200Z Free-standing Dishwasher Logo
22 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
