Question about Frigidaire FDL45P1 Dehumidifier
My dehumidifier FDL 5051 Fridaire is giving me a code of F2. What should I do?
4 Suggested Answers
  • 3 Answers
SOURCE: Frigidaire Dehumidifier gives F2 error code and no longer runs.
ACCORDING TO FACTORY-NO SERVICABLE PARTS AVAILABLE
Posted on Jun 02, 2010
  • 8404 Answers
SOURCE: My dehumidifier is giving me a F2 error message and isn't running
When I searched this error code, I found that F-2 means bad sensor. I found no further information as to what sensor it was. You don't give the name of the manufacturer, so I couldn't search from that perspective.
If it is a bad sensor, you may require professional repair.
Before I took it anywhere to be worked on, I would be certain that the catch bucket was setting square (indicating no water in the bucket).
Thanks for your interest in FixYa.com
Posted on Dec 26, 2009
  • 3 Answers
F1 is room temperarure sensor error. F2 is tube temperature sensor error.
The room sensor usually is located in the front of the condenser. The tube sensor is usually plugged in a tube near the condensor.
The tube temperature sensor (thermistor) should be about 10K ohms.
Posted on Jan 12, 2013
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
The F2 code is on in the humidity window of my Frigidaire dehumidifier? Not in manual. What does this mean?
Good Morning friend, thank you for your inquiry!
I see that you are having trouble with your Frigidaire dehumidifier displaying an error code of "F2". Typically, an "F2" error code stands for a miscommunication error. This could be a possible problem with a sensor or control panel. I would suggest performing a reset and that can be completed by disconnecting the power from your dehumidifier for roughly ten minutes. If you are still under warranty I would recommend contacting your manufacturer to see if any additional assistance can be provided. Hopefully this is helpful. -Matt
Feb 13, 2015 | Frigidaire Dehumidifiers
What causes the compressor to cycle on & off
Hello friend, thanks for your post!
Based off what you have explained your Frigidaire dehumidifier's compressor cycling off and on could be resolved by a couple of troubleshooting steps. Check the filter to make sure it is not dirty, if the filter is it could cause your dehumidifier to work improperly. Verify nothing is obstructing your appliance from proper intake of air. If you go through those steps and your appliance is still not functioning properly you might want to reach out directly to the manufacturer to determine the warranty coverage on your dehumidifier and the procedures to any potential remedy. I hope this helps to some degree. -Matt
Aug 26, 2014 | Frigidaire Dehumidifiers
Frigidaire dehumidifier has a F2 error and will not operate
Hello - Typically error code F2 indicates a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer to verify if the part is available and can be replace. Some do, some don't. Also confirm if the unit has a limited warranty on such concern.
Oct 20, 2012 | Whirlpool Dehumidifiers
Dehumidifier wont turn on or reset. code comes up as F2 and wont reset. Cleaned off filter. no help. any ideas you have would be appreciated.Just bought it last year. we have the hose connected to a...
To figure out what Code F2 is, I took a look at the Owners Manual for the Model # AD70USS, Strangely, the Owners Manual doesn't list an F2 Code or any codes for that matter. Because that model number humidifier, does not have an LED screen.
Never the less, to reset your unit using an alternate method. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and the dehumidifier should have reset itself. If it doesn't check the positioning of the water bucket, to make sure it's contacting the safety switch. Eventhough, you're using a drain home, it's still important.
Hope this helps you solve the problem.
May 08, 2011 | Whirlpool AD70USS Dehumidifier
How to fix f2 message? what is wrong?
If the display reads "F1" or "F2", a sensor has failed. Contact your Authorized Frigidaire Service Center.
Feb 21, 2011 | Frigidaire FDF50S Dehumidifier
Dec 26, 2009 | Dehumidifiers
Aug 31, 2009 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
342 people viewed this question
Top Frigidaire Dehumidifiers Experts
Lawrence Oravetz
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
