Question about ViewSonic PJ256D Multimedia Projector
I have a Viewsonic PJ256D projector and it will no longer show a display from a computer. I also can press the menu button and the menu doesn't come up. The unit continues to search for a display signal
  • 1,472 Answers
Brorob777
Alot of times if the projector is not displaying the info from your computer it has to do with drivers or the actual resolution that the video card is set to. Note most projectors only support standard resolutions like 800x600 and 1024x768. You might try setting the video card to these resolutions to see if this makes a difference. The links below will help you do this.
How to change your Windows XP display settings
How to change your Windows 7 display settings
If you still have trouble the issue may be with the driver all together and you just need to uninstall and reinstall your video card drivers.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Nov 12, 2010
How do i reset lamp timer in my projector
  • From page 55 of the manual (http://www.projectorcentral.com/pdf/projector_manual_2451.pdf): Press the MENU button to display the "MAIN MENU", and then press the up arrow or down arrow button to select "OPTION2". Press the ENTER button to display the "OPTION2" menu, and then press the up arrow or down arrow button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds. The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Dec 13, 2013 | Panasonic PT-LB10VE Multimedia Projector
Computer screen on, Projector off
If you are running Windows 7\8:
Leave the ViewSonic projector on.
Right click anywhere on the desktop and select "Screen Resolution".
In the display column, it will give you an option to select your computer monitor, the ViewSonic, or to clone the displays.
Select your computer monitor display only.
Shut off the ViewSonic projector.
If you are running Windows XP:
The process is basically the same except you find the settings under Control Panel > Display.
Jul 09, 2013 | ViewSonic Office Equipment & Supplies
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Mar 14, 2011 | ViewSonic PJ501 Multimedia Projector
I have my computer on and connected to the projector viewsonic pj550. I then turn on the projector but it does not read the computer.
Assuming that you have all the connections between your computer and the projector already performed, you should check in you computer's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops and computers need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops and computers will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
Some computers have an icon in the tray area at the bottom right part of your screen for the display characteristics. Clicking on it shows a menu where you can select the graphical options for your computer, and there must be an option for the selection of a dual display mode through which you can select computer + monitor (projector)
This same function can be called from the Control Panel in your computer. Assuming that you are using Windows XP, you will need to go to Start > Settings > Control Panel > (Graphics Adapter Configuration Setup), where (Graphics Adapter Configuration Setup) will depend on the graphics adapter chipset used in your computer (Intel, nVidia, ATI, VIA, etc). There, you might have the same options to select a dual presentation mode, to show the things in your computer display and/or your projector.
If even with these indications you are still not able to make your computer show its information through the projector, please send us more details on how you connected your computer to the projector, as well as the brand and model of your computer and the operating system you are using.
Hope this information can be helpful!
Mar 09, 2011 | ViewSonic PJ550 Multimedia Projector
Can't get my Viewsonic projector to project an image AND show image on my laptop screen
Hold the FN+CRT/LCD or (it could be an icon/image of a screen) simultanesouly and then keep press the CRT/LCD key it should eventually get around to displaying an image on just the projector or projector and laptop screen
Jun 08, 2010 | ViewSonic PJ500 Multimedia Projector
View sonic projector
Go to menu and choose option. Then choose lamp time or filter time, depending which one you want to reset and keep pressing reset-button for 3 seconds
Jul 23, 2008 | ViewSonic PJ551 Multimedia Projector
59 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
