Question about Western Digital Caviar SE16 (WD5000AAKS) 500 GB SATA Hard Drive
WD5000AAKS not recognized
I have a WD5000AAKS external drive. It stopped working. Spins up when I plug it in and then shuts down. I would like to try to recover my data from the disk without spending a fortune. Any suggestions on how to recover my info myself?
  • Anonymous Apr 23, 2009
    .ummmm re-read the first user's post. The drive won't say powered on! Doesn't matter if it's connected directly or via USB, etc. It won't stay powered on. I have the same issue.
Take it apart and get a bridge cable called IDE to USB or ATA to USB.
Connect the cable to your PC and take out the files.
Posted on Jul 08, 2008
500 gb and only available 32 gb
Your bios is too old. Put the drive into an external USB case and it will recognize the full capacity of the drive. You can get a case from any store that sells computer parts.
Feb 25, 2014 | Western Digital Caviar SE16 (WD5000AAKS)...
Western digital 2tb my passport keeps flashing; not detected
Remove the drive from the external case it is in and connect directly to your computer - see if the bios recognizes it. If so, the OS will do so also and you can access it. Also means the electronics of the external case are no good. If not recognized in other machine, the hard drive has gone to hard drive heaven and needs to be replaced.
Sep 08, 2017 | Western Digital Computers & Internet
Laptop not registering portable hardrive, it powers up yet does not appear as usable.
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 06, 2011 | Western Digital (WD5000AAKS) 500 GB SATA...
After a year, this WD50000AAKS just stop working and cannot find in BIOS. Stay away from this Western Digital SATA drive ****.
the problem is the controler og the drive wich is:
Marvell, 88i6745-TFJ1, internal EEPROM: - this chip is used in Western Digital's Tornado family, eg WD5000AAKS-xxTMA0, WD5000AAKS-xxYGA0, WD3200AAJS. - it has a common failure mode that mimics head/media faults, eg clicking, spin-down.found it here: http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
Nov 28, 2009 | Western Digital (WD5000AAKS) 500 GB SATA...
My pc doesn't recognize my verbatim 1000gb external hard drive, error "unknown device"
Did the 1000gb external hd come with instructions?
Did you read them?
Did you Install The Software for this Device?
If not. Try plugging it in all the usb ports.
Try shutting down the PC, when it's off plug in the 1000gb external HD,
Restart the Computer, If Windows still dosen't recognize it, then it's most likely defective, and should be returned. Try purchasing a higher quality brand.
Nov 20, 2009 | Verbatim VER95327 USB Hard Drive
Use wd5000 from an HP as External
The best way is to use a desktop system. Leave one hard drive plugged into the primary IDE connector and unplug the CD-rom from the secondary connector and plug the other hard drive into that cable. Reboot your computer and they will show as a C and D drive.
Aug 16, 2009 | Western Digital Caviar SE16 (WD5000AAKS)...
Drive is a blinking brick of garbage.
Is the hard drive a USB external device?
Does the hard drive spin up at all or does it make clicking sounds?
If the hard drive spins it may not be faulty, it may be a faulty USB hard drive adapter case.
Put the hard drive in another USB hard drive adapter and connect it to a computer, if it still doesn't work then the hard drive has died.
Jul 24, 2009 | Seagate Free Agent Go Small 12 GB USB...
Segate FreeAgent 750GB external hard drive
my iqube extenal hard drive is not working was dropd down, I have tryed plag and play and it shows the light and fun inside working and when you staart uyou can ear like its start but stops after few seconds
Oct 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Silly question
short answer....No.... your PC stops all ther services as it shuts down, however if you are going to remove ther drive before shutting down use the disconect USB device icon ( usually next to the clock) to stop your drive before removing it
Sep 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
I soo frustrated
Where do you hear the clicks? on the hard drive? the fan (assuming it's the power supply)? Please explain more... Thanks!
Dec 07, 2007 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Western Digital Caviar  SE16 (WD5000AAKS) 500 GB SATA Hard Drive Logo
2,392 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
