Question about Tag Heuer Kirium (CL1212.BA0705) Wristwatch
How can i change the battery in an Aquaswiss TRAX watch?
4 Suggested Answers
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss trax watch
AQUASWISS TRAX MODEL:
For clarity:
There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
Top knob: #1
Middle knob: #2
Bottom knob: #3
To adjust the stopwatch feature:
1. Turn #2 counter-clockwise until it pops out to its adjusting position.
2. Pull #2 towards the right until you feel the first click. (There are two click positions).
3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
Now you are ready to calibrate the stopwatch feature.
4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
You are almost done.
6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
Your watch is ready to use.
The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Posted on Jan 25, 2008
vsndesigns
  • 5 Answers
SOURCE: how to adjust the band on a aquaswiss trax watch
Warning: This is if you don't have any professional watch tools. And I definitely recommend you taking it to a jeweler first.
That being said...
I was able to adjust my band by using a small nail and a pair of needle nose pliers...and Krazy Glue or Super Glue (last warning...you really should take it to pro)...
1. Push the any one of the pins that holds the wristband together until you see it protrude from the other side. While applying pressure to the pin, quickly grab it from the protruding side with the needle nose pliers and pull off the metal cap from the pin.
2. Note you will notice that the pins are actually 2 pieces! They are not screwed together and it makes for a pretty poor design since, one the pins are taken out and then replaced after taking out the appropriate links... they tend to get loose and you will lose that tiny metal cap that holds the pin in place.
3. A professional will have a clamp that is small enough to press these two pieces together. But even that is precarious. I strongly recommend that you carefully apply a drop of crazy glue on each end of the pin, after you are finished.
Final note: I was luck to have spare pins from the links I removed to replace the pin that worked out of its cap. That little sucker is lost to the watch gods. Have fun! Also... you can make final adjustments at the 3 pin location at the wristband release.
vsndesigns
escapement
  • 2334 Answers
SOURCE: How do you adjust the Band On an aquaswiss Trax?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 15, 2009
How can I tell my watch is a genuine aquaswiss
take it to a watch shop and see if they can tell you.
Dec 23, 2016 | Watches
How do I change time on my aquaswiss swiss sport 24 watch
I looked this up and find many images many have only a winding stem and many had it and 2 buttons . there fore it is tough to guess which you have to even suggest how .post you exact photo and then perhaps we can assist you
Nov 26, 2015 | Swiss Watches
Just got myself the new SWISSport M but it not moving
Your watch is a battery powered watch. If it is not running, the first thing to check would be the battery. To turn it on just push the crown in.
Oct 07, 2012 | Aqua Swiss Aquaswiss Trax Wrist Sharp...
Stop screen flashing on nike trax fury
Nike Triax Fury 100 Super
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
How do I set the DAY (not the date) on an Aquaswiss watch? The day is displayed in a separate dial at the 6 O'Clock position on the watch face. The manual does not indicate how to set the DAY. The movement...
Their web site is pretty useless as far as instructions go (as you may have already found) but looking at their range, it looks like your is a "Trax" model.
As a guess, I suggest that you pull out the crown wheel (it may need rotating anticlockwise about a 1/4 of a turn) and pull is out.
I would expect their to be two "out" positions, the second one usually operates the hands and the date, so this leaves only the first position to be available to adjust the date.
Experiment a little to find the function you need!
Sep 18, 2010 | Watches
Looking for an instructional booklet for my aquaswiss sport watch
Thank you for contacting FixYa.<br /> Very difficult to find certain odd brands such as Aquaswiss. You wil have to contact them direct at :<br /> <a href="http://www.aquaswisswatch.com/Scripts/contactUs.asp">http://www.aquaswisswatch.com/Scripts/contactUs.asp</a><br /> <br /> Best regards,
Aug 25, 2010 | Bulova Watch
How do I get a steal band for my Aquaswiss Trex watch?
look for a tag store near by. if u cant find one most jewelry stores with a shop (not in a mall) can either do it there or send it out. sometime the band can be fixed
Oct 07, 2009 | Tag Heuer Kirium (CL1212.BA0705)...
Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
Feb 09, 2008 | Watches
How to adjust the band on a aquaswiss trax watch
That being said...
vsndesigns
Dec 25, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
For clarity:
Top knob: #1
Middle knob: #2
Bottom knob: #3
vsndesigns
Dec 20, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Tag Heuer Kirium (CL1212.BA0705) Wristwatch Logo
391 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
