Question about Sharp LL 172A-B 17" LCD Monitor
How can I open the case of a Sharp LL 172A-B 17"
    Guru:
  • 2,178 Answers
Gently pull the frame off because they have lock latches.
Posted on Nov 11, 2010
Testimonial: "Thanks for encouraging me to keep trying to separate the outer plastic case. Eventually I succeeded, but I still could not get at the backlight."
  • aquirt Nov 12, 2010
    Thanks.
    It is not obvious how to pull it off. I've tried and will try again. Are there specific places along the edge where perhaps a thin tool could be inserted to release the latches (depending on which piece has those latches).
  • Rommel Alilin
    Rommel Alilin Nov 12, 2010
    Try pulling the back away from the front frame with a slight force as well. Pry one of the corners with a plastic or wooden material first to lift.
I have a Sharp LCD Monitor LL-172C I upgraded my computer and no longer have sound from the speakers. Someone told me to download a driver but I am unable to find a listing for this model.
For the sound to work, you do not need the driver for the monitor, driver is for the display resolution adjustment.
Do you have the correct sound driver installed in your PC? All you need to get sound to the monitor is an audio cable with stereo miniphone pugs at each end. Do you get sound if you use the PC POWERED speakers attach to your PC?
Give us more details how you have it setup.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 22, 2010 | Sharp LL 172A-B 17" LCD Monitor
When I connect my headhphone to monitor doesn`t work?
If you mean the pale green jack on the back of the monitor, it is not a headphone jack. It is to let you connect the sound output from your computer (usually also a green jack) to a little speaker in the monitor. That speaker is better than nothing, but sound quality is poor.
Jul 30, 2010 | Sharp LL 172A-B 17" LCD Monitor
No signal
Check cable connections. Check using a different monitor.
The only other possibility is that you're trying to drive it with a signal that is beyond the capability of the monitor. But the computer boot-up (BIOS) screen won't exceed the monitor's capability.
May 15, 2010 | Sharp LL 172A-B 17" LCD Monitor
I am looking for a driver for a SHARP "LL-172C-B"
There really isn't any "Drivers" as such for the monitor, Windows should pick it up, as the Monitor "Talks" to the PC and "Tells" it what it "Is". You simply need to connect it up, reboot and use it.
Mar 11, 2010 | Sharp LL 172A-B 17" LCD Monitor
I no longer have sound out of the speakers after upgrading to XP Pro worked fine in Home Edition. Never unplugged anything Please help....Thanks
You have to installed driver on your system, and please let us know the model number of the system so that we can provide you the excat driver.
Feb 21, 2010 | Sharp LL 172A-B 17" LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Sharp ll-t17a4-b backlight
when ever i try to sign in the messanger says erorr code 80072efd how can i solve this matter
thanks
jem
Oct 21, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp LL T17A4-B (Black) 17 in.
Are you using the digital connection?? If so try using both the analog and digital connection then set the digital as the Main monitor in your graphics card interface. To check if the backlight is out, darken the room, and light a flash light into the screen. If you can see a picture, then you need to replace the backlight. Good luck
May 03, 2006 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp LL 172A-B 17" LCD Monitor Logo
162 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
