Question about Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
  • 2,296 Answers
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Posted on Nov 11, 2010
MY PROBLEM IS SO SIMPLE THE SCREEEN SAYS (TONER LIFE END)--->REPLACE (Y) AND (M) :SSSSSS
Remove the "end-of-life" toner-cartridge, and responsibly recycle it.
Insert a new toner-cartridge.
Click 'Y' for "yes".
Jul 19, 2011 | Brother MFC-8660DN All-In-One Laser...
I replaced my brother MFC - 7440N with a new cartridge and still has the sign that says toner life end. How will i fix this?
Check the toner cartridge, side gears, you can see a reset lever (that lever is very important) show in the next picture.(cartridge new)
Jun 28, 2011 | Brother MFC-7440N Laser Printer
Brother HL 3070CW says the toner is low and won't print. It has toner and I have to get something printed for a client
I done on my brother lh3070cw printer cartridge on Message "Low Toner"
First I take off toner cartridge
second - Covered the both Glass Buttons of Cartridge situated right and left side of cartridge (all cartrideg) for Black Electric Tape.
thent install the cartridge in the printer again.
after install the cartridge press SECURE PRINT AND CANCEL BUTTON SAME TIME AND CLEAR THE STR AND STD FOR PRESSING ok BUTTON FOR 2 TIME.
ERASE EACH STR AND STD
THEN PRESS CANCEL
YOU CAN USE YOUR PRINTER FOR END OF THE TONER
Mar 28, 2011 | Brother MFC-9440CN Laser Printer
Can i refill tonner on MFC- 9440 CN laser printer
You can, but it a dirty job. I would not recommend it as the toner powder is very fine and you don't want to breath in this toner powder.
If you don't want to purchase a new toner cartridge, then I recommend you buy a re-manufactured toner cartridge for your model printer. They cheaper than the new Brother toner cartridges and usually contain more toner and the drum cartridge components have been refurbished.
Feb 24, 2011 | Brother MFC-9440CN Laser Printer
What is the Drum?
The drum is a selenium coated sort of roller that has the image of your copy document tranfered onto it. As it rotates this image is tranfered to your new copy paper. It then is demagnetised and the toner returns to the toner catcher. The drum coating has a finite life and the mesaage is telling you that its life is near its end and a new drum or new machine will be required soon.
Mar 22, 2010 | Brother MFC-9440CN Laser Printer
Brother MFC 9440CN
You need to order the drum unit. It's different from the toners. You can replace it after the part comes in - you do not need a technicain to come in to do it for you. You can find the part from Amazon or Brother website.
Apr 01, 2009 | Brother MFC-8460N Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Brother MFC-9440CN Laser Printer Logo
1,819 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
