Question about HP LaserJet 4100dtn Printer
My lazer prints have streaks that resemble tiger marks on the page
  • HP Master
  • 7,733 Answers
Black marks on pages when i print
Do the streaks get fainter as you print more pages?
It sounds to me like have toner on your rollers/fuser.
Print out 10 prints from the printer and see if it improves.
If you remove the fuser wiper cover from the top of the printer and look down you will see part of the fuser roller (DON'T TOUCH VERY HOT) and check if there is toner on it.
John
Nov 21, 2011 | Lexmark T520 Laser Printer
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
On printing, cyan leaks streak marks down pages
our printer at the fire dept is leaving streak marks on the pages we are printing. Can you tell me what the proplem is
Jan 10, 2010 | HP Color LaserJet 2600n Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
HP Laserjet 2820 Streaks on Page
There are 3 parts to the imaging process that could cause your issue. You have the toner (x4), the imaging drum unit (Q3964A) and the fuser unit. If you are getting streaks from all colors, one or more these parts are the issue.
Let's start with the easy stuff:
Open the cover as if you were replacing toner where you can "visually" inspect the toner and imaging drum. Pull the drum out and pull back the "plastic shutter" on the top, this will expose a green drum CAUTION! Too much exposure to light and touching it can cause damage. Just take a quick look trying to see if any of the lines on your page match any marks on the drum. Check the bottom half of the unit as well there should be a white section across the bottom, expect that as well.
Next look at the toner, if you can look at any other color but black it will help you look for the streak marks a lot easeier. If you couldn't see any streaks on the drum on toner cartridges, it's time to look at the fuser unit. Power the machine down and turn it around, unplug it then fold down the blue clips and CAUTION! the fuser heats the toner to the page so if it's been used recently it may be hot. once the clips are down, just pull straight back and look for the streak marks.
Sorry for the book, but I hope it helps.
Jul 30, 2009 | HP LaserJet 2820 Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Whenever I print (noticed on color copies) there is a small streak about 1/3rd into page. It streaks the ink, total about 1/2 in long. Does this just need cleaning? If so how do I do that?
same marks or image on all the prints each time you print is Photoconductor units mistake.normally the photo rod is so clean that only the image by laser is transfered to the page but some case when photo rod is dirty or permanently marked it transfers that image of mark every time you print.It is not adviced to touch that photo rod but in this case one should have to rather buying new one.You may remove the photo unit and clean is very gently without any scratch or it will be permanent for the rest of phot unit life.A little damp non scratching cloth might do the job.you have to look for the mark in very moderate light by examining/focusing on the top layer of photo rod from side to side.be careful in rolling the rod as unused tonner will come on it from the waste chambers as well and you have to deal with this aswell.
ask more please....!
Jan 05, 2009 | Epson ACULASER CX11NF All-In-One Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Dec 03, 2007 | GCC Technologies Elite 12/1200N Laser...
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
HP LaserJet 4100dtn Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
