I installed speakers on my computers, the first one fail, the second start working ok, then mute. no sound.
  • 27,725 Answers
The drivers might have been corrupted
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Nov 12, 2010
My lap sound problem..
Some things you need to check
1. Cable connection of the speaker to your computer and the power cable if its plug in correctly. Normally the Audio cable of the speaker is plugged into the green audio port on the computer.
2. You speaker is on mute. Check the speaker icon located on the lower left side of you desktop. If its on mute then try to un-mute the volume and test the speaker.
3. The driver is not installed properly. Check the device manager if there is a Question/Exclamation mark on the Audio devices.
4 If everything are Ok. try to plug the Audio cable of the speaker to any of your Portable sound devices like Ipod. If that still does not work then you need to replace the soundbar. Contact Dell for a free replacement if still under warranty.
Thank you.. Hope this helps..
Jan 04, 2011 | Dell AS500 Sound Bar Computer Speakers
My two speakers are connected and my computer is not muted,plus the plugs are tight but i get no sound. i have a toshiba satellite p305 laptop with windows vista home premium installed.
Make sure that the speakers are getting power.
Get another speaker, head phones or iPod headset and plug in. See if you get sound then, If everything fails this would indicate a problem with the computer or computer settings.
If other speaskers or headset works this would indicate a problem with the JPM-33 speakser.
Oct 06, 2010 | Jensen JMP-33 Computer Speakers
My PC is not giving sound...what can i do..?
Look for your sound card model and install required drivers.
Oct 01, 2010 | Computers & Internet
Idont have any sound from my laptop...i cant here any sounds when i am playing a music...please help me
hi,, ok this can be a major problem or a very simple one.. you might just have the volume down or muted.. two the buttom right of the screen there should be a speaker icon ,, if not move on to solution 2 ..
1.) double click the icon,, remove the mute and turn the volume lever way up..
solution 2..
click start, right click computer ,, then click properties,, click HARDWARE / DEVICE MANAGER
look for something highlighted in yellow ,, if so you have a driver crash,, if not go to solution 3 and try that and if it fails then continue from here..
go to toshiba's web site,, support / downloads ,, download and install your audio drivers..
solution 3
click start ,, all programs ,, accessories,, system tools system restore.. restore your pc to a time when it was working..
Sep 14, 2010 | Toshiba Computers & Internet
Why speaker is not working ?
first off, make sure everythings plugged in right
speakers plugged into audio out or headphone out on back of computer, power is on, and both speakers are plugged in, then check the muting, if its muted un mute...
if its not muted
try muting then unmuting, i sometimes have that problem...
if all else fails, try turning off your computer then waiting 5 mins, and turning it on, if sound works, then great, if not try a set of headphones you are positive work, plug them into each plug theyll fit in on the front and back, or sides of your computer, if not, chances are you have a broken soundcard...
or a software conflict, did you install anything lately, try uninstalling...
Jan 06, 2010 | Audio Players & Recorders
Logitech
1.
Lets start with the obvious. Make sure the volume mixer control is not muted. This is usually a speaker icon at the bottom of the screen. If you do not see this then go to control panel, sounds and audio devices, and make sure nothing is muted.
2.
check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
Jul 09, 2009 | Logitech X-530 Computer Speakers
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
No sound on laptop
Try:
1. Check if the sound is on mute.
2. Click on Start and select Run. Now type devmgmt.msc and press enter. Check if the sound driver is not installed or has been disabled.
3. Check the speakers. Use external headphones, if the headphones are working properly, means the speakers of Laptop are damaged.
Jan 08, 2009 | Compaq Presario 700 470024-192 Notebook
Speakers not working
hi,
ok so your speakers are alright, but you dont hear any sound when connected to the computer.
1.this might be due to a driver problem. install the correct driver for your sound system and it will start working. to check if the driver are ok, right click on my computer icon on the desktop and select properties. now go to the hardware tab an and click device manager. a yellow mark will in the sound system category will tell of a device driver or conflict problem.
2. if there is no problem as mentioned above... you can try this go to control panel. click the sound icon and check i the device is muted and volume sliders are adjusted.
hope it helps.
regards.
bzoy
Jan 09, 2008 | Dell A525 Computer Speakers
My speakers on my Dell computer quit working.
1) check audio driver is installed in system or not it may have some one remove audio driver.
2)If driver installed check volume is not mute.
3)If all thing is ok check speaker in another system by connecting it.
4) If spk is working in another system. it means sound card of that system is faulty.
Dec 01, 2007 | Audio Players & Recorders
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
