Question about Everest & Jennings Vista Ic Wheelchair
Can't assemble the leg rests - Everest & Jennings Vista Ic Wheelchair
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hi im disabled myself & love to help.Visit :-www.alldatasheet.com & download what info on which product you need info on.Download it to your Adobe Reader as a PDF File,save + print for future ref.Any prob ask again,have a nice day Colin.
Posted on Nov 18, 2010
How to attach kick stand spring on 2006 street glide
With the full weight of the motorcycle resting on the jiffy or side stand when it is placed in the full forward and down position it will lock into this position when the bike is leaned over the left side. If it is not in the fully down and forward position and on a flat/level and firm/solid surface when it is leaned over to the left side the bike may fall down.
To Remove the Jiffy Stand
WWAARRNNININGG
Block and support the motorcycle under frame to be sure that it is securely upright and level and so that the jiffy stand can be moved throughout its full range of travel and so that it will not fall down or onto the repair person when the jiffy stand is removed.
Then move the jiffy stand to the retracted i.e. up position and remove the ****** nut and leg stop from the threaded end of the jiffy stand leg and then move the jiffy stand leg to the full forward position which is the full down position and grasp the end of the jiffy stand spring as close to the frame tube as possible, and then twist and turn the end with needle nose pliers to unhook it from the frame hole. THEN remove the jiffy stand leg from its bracket, inspect the entire jiffy stand assembly for worn or damaged parts and replace them as found necessary.
To Install the Jiffy Stand
First lubricate the jiffy stand leg with an Aerosol Anti-Seize Lubricant but only in the area of the jiffy stand leg part that rotates within the bracket. THEN insert the threaded end of the jiffy stand up through the bottom of the bracket and with the jiffy stand in the full forward position, partially install the spring end into the frame hole and with a rap to the spring with a rubber mallet fully seat it in its hole. Be careful to insert the end of the spring into the hole at the front of the jiffy stand leg piece in front of the jiffy stand leg piece weldment because if it is inserted from the rear of the hole in the leg piece the coil of the spring will interfere with and rub on the leg piece when the jiffy stand is used and if it is installed incorrectly over time it will wear and the motorcycle could fall over due to this wear. THEN while holding the jiffy stand leg at the full forward position, install the leg stop over the threaded end with the stamped side down, install the ****** nut and tighten it to 43-53 ft-lbs which is 58-72 Nm. NOW verify that the longer side of the leg stop faces towards the rear of the motorcycle, extend and retract the jiffy stand leg several times to verify that it operates properly, freely moving to both the full up and the full down positions with no spring or other interference or contact and verify that the rubber stop is correctly in place on the jiffy stand prong because without the rubber stop correctly in place the stand will make improper contact with the lower frame tube when the jiffy stand is retracted and will then likely chip and/or nick the powder coat. AND, of course if the rubber stop is deteriorated or missing. Replace it with a new one. FINALLY carefully remove the support blocking from beneath the motorcycle frame and let the motorcycle rest on the fully extended jiffy stand leg.
Sep 15, 2014 | Motorcycles
Tip
Identifying Your Reebok / Robix Studio Cycle
  • 9600
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and dual brake pads.
  • 9800
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and single brake pad.
  • 9900
    Glossy finishes w/angled back legs (stabilizer). Bolt-together frame (assembly required). Rectangle shaped stabilizers.
  • 2000B
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Silver crank arms and belt driven.
  • 2000C
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Black crank arms and chain driven.
  • 3000B Robix
    Black glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and frame down tube. Belt driven with single brake pad.
http://www.sportsmith.net/Categories.aspx?did=CEF96124-843A-4128-9B53-8E10980C9920
on Mar 11, 2015 | Exercise & Fitness
Can not get spring in the kickback lever assembly
The return spring is not supposed to come out, however, remove the e clip and pull out the pin, the spring has a loop at the an arched leg and a leg with a pig tail. Press the arch leg and the pig tail leg together and push the loop up into the hand guard with the pig tail facing toward what would be the rear of the saw, push it up as far as it will go, push the pin back in and re fit the e clip, the arch leg of the spring should now be resting on the top of the pin if you have done ir correctly, and the tail of the pig tail should be protruding.
Mar 27, 2014 | Husqvarna Chain Saw 20" Bar
Washer is unbalaced and tips forward when drawers open
All the resting legs must be balanced to rest perfectly on the floor. Use a water level sensor to set. Use some spacers to wedge the legs to support firmly.
Nov 03, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do you replace a Harley Road King kickstand spring
WWAARRNNININGG
Then move the jiffy stand to the retracted i.e. up position and remove the flange nut and leg stop from the threaded end of the jiffy stand leg and then move the jiffy stand leg to the full forward position which is the full down position and grasp the end of the jiffy stand spring as close to the frame tube as possible, and then twist and turn the end with needle nose pliers to unhook it from the frame hole. THEN remove the jiffy stand leg from its bracket, inspect the entire jiffy stand assembly for worn or damaged parts and replace them as found necessary.
First lubricate the jiffy stand leg with an Aerosol Anti-Seize Lubricant but only in the area of the jiffy stand leg part that rotates within the bracket. THEN insert the threaded end of the jiffy stand up through the bottom of the bracket and with the jiffy stand in the full forward position, partially install the spring end into the frame hole and with a rap to the spring with a rubber mallet fully seat it in its hole. Be careful to insert the end of the spring into the hole at the front of the jiffy stand leg piece in front of the jiffy stand leg piece weldment because if it is inserted from the rear of the hole in the leg piece the coil of the spring will interfere with and rub on the leg piece when the jiffy stand is used and if it is installed incorrectly over time it will wear and the motorcycle could fall over due to this wear. THEN while holding the jiffy stand leg at the full forward position, install the leg stop over the threaded end with the stamped side down, install the flange nut and tighten it to 43-53 ft-lbs which is 58-72 Nm. NOW verify that the longer side of the leg stop faces towards the rear of the motorcycle, extend and retract the jiffy stand leg several times to verify that it operates properly, freely moving to both the full up and the full down positions with no spring or other interference or contact and verify that the rubber stop is correctly in place on the jiffy stand prong because without the rubber stop correctly in place the stand will make improper contact with the lower frame tube when the jiffy stand is retracted and will then likely chip and/or nick the powder coat. AND, of course if the rubber stop is deteriorated or missing. Replace it with a new one. FINALLY carefully remove the support blocking from beneath the motorcycle frame and let the motorcycle rest on the fully extended jiffy stand leg.
CAUTION
Jun 03, 2011 | 2006 Harley Davidson FLHRCI Road King...
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
I have a quantum 6000 chair and whenever I need to raise my chair for a period of time, my legs just dangle and begin hurting. Any suggestions or solutions for a temporary foot rest while my chair is...
Jal Check with your provider and ask them for a pair of Elevated Leg rests for your chair. They might have to install the holders for the leg rests but that is an easy job. And they are fairly inexpensive and can be put on and taken off easily. Hope this helps you
Nov 12, 2010 | Pride Mobility Products Quantum Jazzy 500...
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Everest & Jennings Vista Ic Wheelchair Logo
65 people viewed this question
Top Everest & Jennings Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Louis Smith
Are you an Everest & Jennings Health and Beauty Expert? Answer questions, earn points and help others
