Question about Dayton (3E379) Heater
I have a dayton fuel trimmer heater and when turned on the flame comes on for about 5 or 10 minutes and then the flame shuts off and it blows cold air, after about 20 minutes the flame comes back on and it does the same 5 or 10 minute hot then cold air.. How do I fix this. Thanks in advance for any help you can give me.. SC
    President:
  • 3,074 Answers
This site may help, Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Posted on Nov 11, 2010
I am having trouble getting my Dayton Portable Oil fired Heater Model # 2E218E to keep running.
May be the primary control if you already replaced the photocell. Make sure the photocell is in direct line of sight with the flame.
Jan 04, 2014 | Dayton Heating & Cooling
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Nov 22, 2011 | Dayton Gas Furnace Heater
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
I have a 75k BTU Dayton hanging gas heater that the fan comes on intermittently. The flame will shut down and try again, then the fan will come on.
This problem is caused by a bad flame sensor (looks like a spark plug) which can be cleaned by sanding or with steel wool.
Dec 02, 2010 | Dayton Gas Furnace Heater
Dayton space heater 350,000 btu
Sounds like you have a bolwer motor or fuel pump that has bad bearings, as it runs, it starts to bind up, and get to the point where it is pulling to much juice to turn it, and the fuse does it's job and blows?
If you could give be a bit more detail, I can help you furthur.
Please rate the new guy :)
And get back to me, so we can get the problem fixed for you.
Lets get this fixed.
Sincerely,
Paul Gibson
Apr 04, 2010 | Dayton Electric Space Heater - Model D-F79
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
Dayton 175k heater
the air pressure is not correct on either units.the photo cell DOES NOT look for light any more,it count the light flashes.if the flame is not in the right possition the heater will shut down....after the unit ignites the ignitor is no longer used to keep the unit working,just the fuel that is being fed to the flame ball.that's why the pressure is so inportant.......
Jul 08, 2008 | Dayton E51 Oil Filled Utility Heater
Dayton (3E379) Heater Logo
227 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
