Question about Panasonic NN-P295SF Microwave Oven
I have a panasonic nn-s255wfx microwaive I believe has blown a fuse. I went to use it and right after I turned it on all power died on it and I heard a buzzing/click behind the control panel. It now has no power at all but the circuit breaker did not trip and the power outlet is fine. I'm trying to find the fuse and panasonic said it is not user servicable so they wont tell me where it is. Can you tell me the exact location and what it looks like?
Illeagle
  • 525 Answers
SOURCE: Microwave causes GFCI on another circuit to trip
You may have a shorted High voltage component. Possibly a recttifier,aka, diode. This should only be replaced by an experienced repairman as an extremely high voltage shock potential exists.
Posted on May 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: no power to the unit, fuse tested fine, outlet is working
Sorry, but your subject line got cut off.
Assuming the outlet is fine, it may be a thermal cutout / thermostat on the magnetron or on top of the cavity.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Jan 02, 2009
nuwan chinth
  • 111 Answers
SOURCE: Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Posted on Jan 12, 2009
JSEhandyman
  • 368 Answers
SOURCE: Tripping circuit
Hi lbeaujuin,
You don't say how long this has been going on; I'm going to presume it's a recent development.
Several possible scenarios come to mind. I'd first look around and see if any other appliances have been connected to that circuit. In my area (Minnesota), the electrical code requires that microwaves have their own dedicated circuit and breaker; if this is not the case, you need to see what else is competing with your microwave for that breaker's power supply.
One other possible cheap fix - in case the breaker is defective, try swapping out the breaker in-question for another of the same rating (DO NOT, repeat, DO NOT put in a bigger/higher-rated breaker without having a qualified electrician OK it). If this isn't the problem, it never hurts to have a spare circuit breaker on-hand. Might even be able to switch around with another of the same rating, just understand that you'll lose power to both circuits for the duration of the test.
If it's on it's own dedicated circuit, then it's likely the oven itself with an internal short of some kind. Because I don't know your level of skill in dealing with 110V AC electricity, my recommendation is that you have someone qualified open it up and start checking short-circuits with a multi-meter, observing all safety precautions.
If you've isolated the problem to being the oven, and it's going to cost more to troubleshoot than replace, you might be able to cut a deal by trading-in your old oven against the new one - - if the shop you buy from has quailfied repair people on-staff, they might be able to refurb and re-sell it used.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Feb 21, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic nn-s255 wont turn on
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Posted on Sep 12, 2009
How do I replace the light in my Panasonic nn797s?
Remove the case and replace the lamp located between the magnetron tube and the control panel. If I remember correctly there is one phillip screw holding the base to the oven.
Oct 12, 2014 | Panasonic Luxury Full-Size 2.2 Cu. Ft....
Why won't my panasonic inverter microwave will not turn on?
check when the fuse is blown,means inverter unit is faulty
Aug 05, 2014 | Panasonic NN-S251 Microwave Oven
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
NN-A774SBBPQ Invertor & Cat-Clean model.
no 3rd fuse as far as i know just the two on the mains pcb and the plug i would test all three fuses again but if the short has gone back up to the control panel them that might be why its not coming back on if it has blown the control pcb it will show up as ablack mark on the pcb sorry cant be nore help its the sort of thing i would need to see as it could be a door micro switch as well gd luck dont forget to unplug the unit
Oct 05, 2009 | Panasonic Microwave Ovens
Panasonic nn-s255 wont turn on
William E. Miller
prototech@usa.net
Sep 08, 2009 | Panasonic NN-P295SF Microwave Oven
My new microwave is completely dead
good day,
hope this link below will solve your problem.
kitchen appliances
May 24, 2009 | Panasonic NN-H504WF Microwave Oven
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
Runs for 3 seconds
check inverter transter or Magnetron short to be repalce
G.K.MAHENDRAN.
Date: 09.05.2008
May 07, 2008 | Panasonic NN-S540 Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
319 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
