Question about Epson Stylus Photo R320 InkJet Printer
The colored photo that I printed came out pink. I changed one of the ink cartridges and that didn't help. Then I tried to print an email and that came out pink and blue and was missing all black. So I put in a new black cartridge and that didn't help. So in desperation, I put in ALL new ink cartridges and now it doesn't print at all! When I do a nozzle check, the page comes out blank. When I do a head cleaning, I get a blank page. ...the same blank page for a print head alignment. Now what??
    Guru:
  • 2,178 Answers
Get a HP printer.
Posted on Nov 11, 2010
How do I change the toner HP Officejet 6310 All-In-One
Hi, the officejet 6310 takes ink and can be ordered from most online stores like staples, cartridge world and amazon, All will vary in price, but always stick to the official HP inks although they are more expensive the compatibles do cause problems. below is a link to the cartridges you will need to purchase.
http://shopping.cartridgeworld.co.uk/home.php?cat=901
Unfortunately i cannot attach files to this message otherwise i would put the manual on here, which on page 95 shows step by step on how to change the ink cartridges. I can email this to you if you provide an email address for me. below i have copied the instructions from the manual, but there missing illustrations, so might be a bit hard to follow. please let me know if you require any further help.
Replace the print cartridges
Follow these instructions when the ink level is low.
Maintain the HP All-in-OneNote When the ink level for the print cartridge is low, a message appears on
the display. You can also check the ink levels by using the software installed
with the HP All-in-One.
When you receive a low-ink warning message on the display, make sure you have a
replacement print cartridge available. You should also replace the print cartridges
when you see faded text or if you experience print quality issues related to the print
cartridges.
To order print cartridges for the HP All-in-One, go to www.hp.com/learn/suresupply. If
prompted, choose your country/region, follow the prompts to select your product, and
then click one of the shopping links on the page.
For a list of print cartridge numbers, see the back cover of this guide.
Tip You can also use these instructions to replace the black print cartridge
with a photo print cartridge for printing high-quality color photos.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
1 Print cartridge door
2 Print carriage
3. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 10
96 HP Officejet 6300 All-in-One series
Maintain the HP All-in-One1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge. The HP Inkjet Supplies Recycling Program is available in many
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
6. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
User Guide 97
Maintain the HP All-in-One7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
11. The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
12. Press OK.
Dec 02, 2011 | HP Officejet 6310 All-In-One InkJet...
How to install ink cartiges
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
Work with print cartridges 69
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Aug 27, 2011 | HP Photosmart C4280 Aio Printer
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
slot on the left.
5. Pull the print cartridge towards you out of its slot.
container.
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
All color images are printing pink/orange. all inks are only 1% used. the very first photo i printed was beautiful. every photo since has been the pink orange color. even the black is not printing well
This sounds like a blue ink cartridge failure or a clogged blue ink nozzle. If you have cleaned the nozzles, I would try another blue cartridge. if this does not solve the problem more aggressive cleaning may be required. Let me know and we can go throught the process. Thanks.
Apr 21, 2011 | Lexmark Prospect Pro205 Wireless...
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Changing cartridge on printer
The Basics manual from HP:
http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
cartridges are not docked safely when you try to remove them.
slot on the left.
print cartridge.
connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push on the
alignment sheet.
Note If you have colored paper loaded in the input tray when you align
the print cartridges, the alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print
cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
choose your country/region, and then click Contact HP for information on
calling for technical support.
Jan 03, 2009 | Office Equipment & Supplies
Changing ink cartridge on the HP Photosmart C3180 all in one
slot on the left.
print cartridge.
connections.
alignment sheet.
Nov 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
Epson Stylus Photo R320 InkJet Printer Logo
546 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
