Question about Graco SnugRide - Giselle Infant Car Seat
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
  • Anonymous Nov 04, 2008
    Same problem but with a 3 point seat.
    Problem Solver:
  • 13 Answers
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Posted on Jun 19, 2008
How do I put the top cover of the washer back? I had the dryer put on top of the washer when it was first installed and took the washer cover off so the dryer can be bolted and sit on top of the washer...
Lay the panel on top of the washer with the screw holes pointed towards the back. Slide the panel forward until it is flush with the control panel. Reinsert the screws in the rear to secure.
NOTE: There should be a couple of tabs near the control panel on most of these washers that the top panel slides into to lock in place.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this help you.
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
My early 90's whirlpool washing machine tub is off center & leans towards 5 o'clock. when it fills, some of the water spills out the back over the tub frame. I took the cover off and it is crooked. ...
yes a small spring under the washer at the rear came off do to rust find the spring and atach to a 3/4 '' hole on the back of cabinet
basickley moving it to a new point
Feb 13, 2010 | Kenmore 22422 Top Load Washer
I took the cover almost off and now don't know how to put the harness back together
have you received an answer yet??? I have had to take off and put back on mine at least 10 times now.....If you still don't have an answer I will take mine apart and re-cover and write steps down as I go....it is a hard cover to take on and off....it still takes me about 20mins to get it all together....you may want to consider buying a easy remove cover to go overtop of your pre-existing one. Let me know if you need help
Jun 28, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
May 08, 2009 | Century Encore 5-point Harness
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
5 point harness reattachment - HELP
Contact Peg Perego & they will give you answers over the phone or send you a manual for free (email or snail mail).
800-671-1701
Jul 30, 2008 | Peg Perego Pliko P3 Classico Freestyle...
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Put back together
2 clips go in top center on back. one clip on each side by handle swivel points. also there is a string you thread underneath th front. Hope that helps
Nov 10, 2007 | Evenflo Aura Traditions Travel System...
Graco SnugRide - Giselle Infant Car Seat Logo
968 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
