Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do you take off back panel of washer - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
  • Whirlpool Master
  • 8,220 Answers
You do not work from the back sides of this washer. Their are several different styles of direct drive washers but they all are put together the same way. What you do is swing up the controls. Unplug the lid switch pop the S-clips and tip the case towards you. Then sit it out your way. Older models have the screws exposed so you can easily remove them. Newer models have the screws hidden and some models have the screws in the back. The latest models don't use any screws at all. you simply slip in a putty knife under each end and ppop the control.how do you take off back panel of washer - themobilian_109.jpg
I have a service manual and 4 videos HERE
Posted on Nov 11, 2010
What does F 02 code mean ?
Normally a simple fix: Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out. With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out clean and install it back into washer. Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
May 04, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
How do you remove the top
The top panel of the washer (model WM2277h) slides off towards the back of the washer. There are two white tabs on the back of the top panel. Each tab has two screws securing the tab to the top panel and the lower panel. Remove the lower screws from each tab and slide the top panel off by pushing it towards the back of the washer. Do not try to pry the top panel off due to damage to the top panel...
Nov 23, 2010 | LG WM2277H Front Load Washer
How do I put the top cover of the washer back? I had the dryer put on top of the washer when it was first installed and took the washer cover off so the dryer can be bolted and sit on top of the washer...
Lay the panel on top of the washer with the screw holes pointed towards the back. Slide the panel forward until it is flush with the control panel. Reinsert the screws in the rear to secure.
NOTE: There should be a couple of tabs near the control panel on most of these washers that the top panel slides into to lock in place.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this help you.
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
HOW DO I GET FRONT PANEL OFF OF WHIRLPOOL DUET TO GET TO MOTOR CONTROL UNIT
If the model number is correct, the Motor Control Unit (MCU) is located in the bottom of the washer on the right hand side (as viewed from the front). You can access the MCU by removing the lower toe panel under the door, or by removing the back panel of the washer.
The access screws for the toe panel are under the bottom front edge of the washer. You may have to prop the two front feet of the washer up for better access (a 2x4 works well for this). With the screws removed, the panel will drop down, then come off.
The removal of the back panel should be self explanatory. Just remove the screws around the entire perimeter of the back panel and remove.
HINT: It may be easier to remove the front and back panels to have full access to the MCU from both sides.
The following websites have excellent exploded view parts diagrams of your washer to assist you in locating and properly identifying the components of your appliance:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
The MCU is listed as item 1 under the "Pump and Motor Parts" section.
If you have any questions about this repair, please post back and let me know. I hope this is helpful to you.
Apr 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer drips after cycles are completed.
yes the water inlet valve is bad! might be easier to remove the base, when you remove the base the back stays connected to the frame. just unplug the machine,remove the end caps on your control panel and remove the screws holding it on, them pull slightly forward and up to fllip the control panel back it has plastic hinges on top,be careful not to break them. then unplug your lid switch, with a screwdriver remove the 2 gold clips that hold the base to the back panel, then open your lid lift from back towards you and the whole base will come off leaving the back panel and frame, should be a whole lot easier to replace the valve, then replace reversing your steps , when you are lifting off the base look at the bottom of machine through your lid and you can see how to put it back on the frame! not to hard!
Feb 17, 2010 | Kenmore 24902 Top Load Washer
How to install the rear clip on the whirlpool washer lsr9434pq4
Follow these steps:
1. First, make sure you have the washer casing seated correctly on the frame. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you.
3. Reinsert the brass clips by placing the 90 degree bend of the clip into the slot on the back of the washer first. With the clip inserted on the back panel, forcefully push the J-hook end of the clip down into the opening on top of the washer. The clip should snap back into place and the washer casing should fit tight against the back panel and frame.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each clip has a 90 degree bend at one end, and a j-hook end at the other. The 90 degree bend fits into the back panel slot, the j-hook fits into the top panel. Make sure the clip is properly oriented, or it won't fit properly.
Nov 12, 2009 | Whirlpool LSR9434PQ Top Load Washer
Getting off the End Caps
The end caps do not come off on this type of control panel. There is a retaining clip holding it in place at each front corner. You need to insert a putty knife between the top panel and control panel at the left and right front corners. Push the knife straight in from the front and push to release the retaining clips while lifting the panel. Once both clips ar released, the panel will open up. You can view a diagram of the console at searspartdirect.com. Just type in your model number and look under the "Control Panel Parts" heading. The retaining clips are listed as item number 8.
NOTE: Sometimes the clips will come off and fall down inside the washer cabinet. If this happens, you may be able to retrieve the clip by moving the washer and looking underneath. However, if it becomes caught somewhere inside the cabinet, you will need to remove the exterior cabinet to retrieve it. Just follow these steps:
1. Unplug washing machine.
2. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
3. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
4. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console by aligning the retaining clips with the holes on the top panel and pushing straight down until you hear a "click".
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Sep 18, 2009 | Washing Machines
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
