Question about Panasonic Audio Players & Recorders
I own a vintage (1991) Panasonic RX-DT707 "Cobra
Bogdan
  • 198 Answers
SOURCE: My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Posted on Feb 16, 2007
  • 30 Answers
SOURCE: Missing band selector.
more than likely you cannot i would suggest to get a new boombox.
Posted on Jul 17, 2007
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
simplemitch
  • 752 Answers
SOURCE: CD player on boombox
The laser is dead or damaged. Try swabbing the laser with rubbing alcohol on a Q-Tip, then IMMEDIATELY blowing dry with canned air. If this fails, the laser is dead. If it is a Sony KSS-2xx series laser (try to peek in the laser slot to see the decal on it) you can get replacements online. If not, it's junk.
Posted on Aug 04, 2008
  • 142 Answers
SOURCE: AC power supply problem Sony STR-DE935
The part is available from tritronicsinc.com. It costs $8.74. Just enter the part # and it will come up. Good Luck!! Please rate this solution!! Thanks!
barneyluc
Posted on Oct 05, 2008
Cd player won'start
try cleaning the optics with a soft cloth or Q-tip and isopropyl alcohol(just a drop!!!!) start it again....otherwise replace pickup..... regards, meder's tv service
Aug 15, 2012 | Panasonic RX-D11 Cassette/CD Boombox
Ihave a Panasonic Power Blaster RX ES25 audio vidio. Can you guide me to print off instructions. Make it simple, I am almost 90!!
Click on the link below for the operating instructions. When that webpage opens, click the printer picture in the top left corner of the window.
http://service.us.panasonic.com/OPERMANPDF/RXES25.PDF
Jun 23, 2011 | Panasonic RX-ES25 Cassette/CD Boombox
Can you plug an mp3 or ipod into the RX-DX1 panasonic radio?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Jan 22, 2011 | Panasonic RX-DX1 Radio/Cassette/CD Boombox
Where Can I Buy
Hi, This is the old model of Panasonic. You are lucky, I can find it here at ebay ( used only for U$ 5) : http://cgi.ebay.co.uk/Panasonic-RX-EX1-Cassette-CD-Boombox-/200564719515
Regards, vote please, Jay
Jan 19, 2011 | Panasonic RX-EX1 Cassette/CD Boombox
MY CASSETTE PART DOES NOT PLAY. THERE IS NO SIGN THAT A CASSETTE IS BEING PLAYED.PLZ ASSIST
Sir,
It might that you cassette player have got disangajed from the inter unit therefore you would be required to get it repaired it would not take much money.
Oct 20, 2009 | Panasonic RX-ES25 Cassette/CD Boombox
Record from radio to cd
i don't think this stereo has a cd burner your best bet would be to use online radio (most stations do this now) record straight to your computer and burn cd from there
Jun 12, 2009 | Panasonic RX-ES25 Cassette/CD Boombox
Power cord
sure..type in your manufacturer, and model number and the term 'spare parts' and watch what happens next.
Got backup for your computer?
Feb 14, 2008 | Panasonic RX-ES20 Cassette/CD Boombox
361 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
