Question about Makita 7 1/4" Circular Saw 5007NB
Hi, I have to replace the main housing on a makita 5007mg and can't get the field assembly out of the old housing. Any suggestions? I don't want to apply too much pressure and break something. Thanks
  • Makita Master
  • 7,733 Answers
I overheated my Makita 9557PB angle grinder. I replaced the brushes. Bearings seem ok: the motor assembly turns freely, smoothly, and quietly. The running motor is slow, with a loud "grinding" sound.
Measure the value difference in Ohm between the carbon brushes on the armature there are some collectors in the commutator give an other ohm value if compared to other collectors in the comutator of the armature . if measure turn the blad very slow so the collectros can be positioned to measure the ohm difference. range to measure 0-200ohm on ohmmeter.
If only one brush made trouble ( much more sparking ) then the electric field is not in ohm value balance, control always if there are slide contacts used they are solid. on the field. Measure the difference. between the 2 field coils of the electric field . if its also different replace allways the field and the armature if thats also have problems (BUT DON,T FORGET to order a new drive gear for the armature and new brushes. !!!
Aug 28, 2016 | Makita 4-1 2 in Grinder 9557PB
How to remove field coil from makita hr3000c drill/breaker
Here is a parts breakdown for your drill. Of course the armature has to be removed first. There are two screws holding the field. It should just push out at this point. If not, the housing may be melted to it. Good luck with that. https://www.ereplacementparts.com/makita-hr3000c-rotary-hammer-parts-c-97_380_507.html
Jul 14, 2016 | Makita Drills
Makita 5007mg blade spins wont cut thought
blade bone or sitting upside down on the machine or the drive shaft is worn
Aug 01, 2015 | Makita Saws
How to gear spindle from housing
The unit is retained by two or three screws surrounding a retaining ring on the saw blade side, and I believe there are some screws holding the gear housing on the motor side that need to be removed as well. I just replaced the bearing on mine a week ago, and even though the situation is obvious once you figure it out I was not smart enough to do so, and wasted an hour trying to figure out how to remove that retaining ring over the bearing. Good luck
Apr 05, 2013 | Makita 5007MG Factory Reconditioned 7 14...
Brushes arcing
Brushes arc for several reasons. If the spring over heated and lost its tension or the copper line from the brush to the cap broke/burnt off or the brush wore down too far to be pressed on the armature properly. The replacement brushes you need are Makita part number CB-124. If you still have exessive sparking after replacing the brushes you may have a bad commutator on the armature. The only way to fix that is to replace the armature, Makita part number 512831-0.
Oct 09, 2012 | Makita 5005BA 5-1/2 inch Circular Saw
How to get motor out of houseing on a makita 5007MG circular saw
The armature and field will need to come out. It's quite a bit of work to swap everything over. Here is a parts diagram which should help.
Makita 5007MG diagram
Aug 06, 2012 | Makita 5007MG Factory Reconditioned 7 14...
Need to know where to get a replacment guard for my 5007MG circular saw
if you give me your general area I will try and find a local dealer for you, you can also look in the yellow pages under tool repair for an authorized dealer, but it is faster online to find one. Or if you want you can go to Makitausa.com and they have a locator. Let me know if you need more help before voting please and thank you.
Feb 17, 2011 | Makita 5007MG Factory Reconditioned 7 14...
Makita ML902 Flashlight how to open case housing to repair
Makita ML902 - great flashlight. but I wanted to upgrade the lamp to LED, and found that the POLARITY was wrong . so i HAD to open the dern thang. the 'special tool' and 'keep in-house' conspiracy had me 'fuming' ... turns out if one were to mark the EXACT spot that the pivot occurs with a felt pen, by drilling a small (sized) hole on each side, (stop as soon as the bit is thru! the shiney material that you stop at are lamp straps) then pressing 2 stiff objects from both sides, the head pops off ! one more screw is uncovered, making it an even 4 screws holding it all together. When i opened the case up, one wire wasn't even soldered to the switch ! aargh. so - swapped polarity, re-soldered the connections, add a bit of fresh solder, re-assemble, voila! I love the 9 volt cases, upgrading everything to 12v and 16v lithium 18650 cells. these old Makita ensembles are great! saw, drill, angle drill, light...
Mar 29, 2010 | Makita Drills
Makita 7 1/4" Circular Saw 5007NB Logo
111 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
