Question about Ventamatic Dryers
Model #2414 Ventamatic attic fan
After running for a period of time the fan will start to squeal rather loudly and eventually shut down. Access to the fan is difficult but I have used an oil based spray to lubricate the shaft and the squeaking will stop for a period of time, but will begin again after a few day's. Do I need to replace the motor or entire unit. Any suggestions on greasing/oiling the unit for a more permanent solution?
SOURCE: Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Posted on May 17, 2011
catriver
  • 878 Answers
SOURCE: Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
  • 244 Answers
SOURCE: Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Posted on Jul 11, 2008
SOURCE: maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Posted on Nov 13, 2008
  • 50 Answers
SOURCE: makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Posted on Jan 30, 2009
I have 120v going to fan ,thermostat has been put on 80 degrees and it still won't work .Do the heat sensors go bad ?
The heat sensor or thermal switch can go bad, so can the motor.
Try a few things;
shut off power going to fan. try cleaning out the thermostat housing using some compressed air on low pressure, or use a vacuum cleaner on blow, or a hair dryer on no heat. you can also spray the inside with contact/motor cleaner(home depot electric dept.) and then blow the thermostat out of any dust or particles that may have lodged inside.
To see if the thermostat works at all, turn power to fan on. Take a hair dryer on heat and place near thermostat - to see if fan comes on.
To rule out a bad motor, the thermostat can be bypassed by hooking up the feed wires to the fan itself, if you're handy with wiring.
Ventamatic web site does list replacement parts for fans... Good luck!
Jul 21, 2009 | Ventamatic Gable Mount Power Attic...
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Shutters closing while running
The shutters should be gravity closed, which means they are counter weighted just enough to close with no air flow...  when the fan starts, it will create a slight pressure differential across the shutters - when that pressure overcomes the counter weight, the shutters should open...  I assume you open windows and/or doors when the fan runs...
I would check for the following items: a) (unlikely) check to see if the counter weight is adjustable, if so, it may be slipping and needs reset.. I think this is unlikely as I think most shutters do not have adjustable counter weights -- check last)
b) check your attic vents to the outside -- the air being blown into the attic must escape to the outside world, otherwise it will build up pressure and the airflow will drop or stop altogether -- this sounds like what is occurring, at slow speeds, there is insufficient airflow to open the dampers, at high speeds, they open long enough for the pressure to build up and then they close as the air flow diminishes
c)  have you replaced windows, caulked up windows, made any modifications to reduce the flow of air into the living areas -- air must enter the house just as air must leave the attic (assumes you don't open windows or doors)
d)  if you have a fireplace, check to make sure some animal or other hasn't plugged up the chimney -- if the house is tight, the attic fan will pull air from the chimney unless it is blocked
hope this helps...
Jul 25, 2008 | Ventamatic Direct Drive Whole House Fan...
Attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Jul 11, 2008 | Kitchen Ranges
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Over the range MV Oven shuts down from heat
it is triggering the overtemp switch. try to check the vent outlet, it could be clogged with dirt. or the cooling fan of the magnetron is no longer running. could be stuck up because of not being used for a long time.
Feb 20, 2008 | Microwave Ovens
Dryers Logo
963 people viewed this question
Top Ventamatic Dryers Experts
Are you a Ventamatic Dryer Expert? Answer questions, earn points and help others
