Question about Jenn-Air Kitchen Ranges
Jenn Air Range SVD48600P Oven heating elements not working. The Bake element burned out ( actually shorted and melted a 1 " section) and I replaced the bake element. Niether the top nor bottom element will heat up. I can hear the relay closing, but no heat. The wiring diagram shows Hi Limit sensor. Can this be "reset"? Where is it so I can check if it is open or closed? Any other suggestions?
  • WINKjr Nov 11, 2010
    The Over Limit sensor is #23 in diagram#3 from appliancepartspros.com
    The two relay boards are #28 and #29, but I do not think that is it. I am not sure wher the main relay board is for the two elements.
  • WINKjr Nov 12, 2010
    Thanks for your help silverdragon. It was #23 the Hi Limit Switch like I thought. Had to take the whole top half of the range apart to get to it. Jumpered it for now until I can get the part. Everything is working well.
  • Jenn-Air Master
  • 12,061 Answers
Http://www.appliancepartspros.com/partsearch/model.aspx?model_id=43495&diagram_id=661873#d661873
Above is your parts diagram.
If the element melted then a considerable amount of current must have flowed through all attached Componentry. Including the Element switches which are most likely burnt out too, the contacts evaporate.
You also have Thermistor sensors these too most likely will be Open Circuit, you need to check with a meter, they should be SHORT CIRCUIT.
The sensors cannot be "Reset" they must be replaced.
You simply need to trace out where the wires go BACK to the controller, and see if you have voltage at this point, work back testing as you go, until you find the mains voltage again, the replace any components that are NOT passing the current through.
The circuit is pretty simple, from the mains IN switch, to the Element Control from the element control through the Relay, and onto to the element itself. The relay can also be "Turned Off" via the "Control circuitry" too.
Posted on Nov 12, 2010
  • 3,083 Answers
I found the oven sensor, but couldn't find the hi-limit sensor. In the following web page, you'll see diagrams for your oven, along with parts lists and a schematic. The oven sensor is part number 12 in diagram number 8(click and scroll on the diagrams on the left side to go to other pages and drawings). You'll be able to find the part with a little patience. In the diagram that will come up (number 7), parts 9 and 10 look suspicious, also. They're usually a round, maybe 1/2" raised metal encapsulated part with two screws to secure them to a surface, See what you can figure out- here's the site:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45156&diagram_id=634997#d634997
Good luck, and hope this helps.
Posted on Nov 11, 2010
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i...
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
Jul 26, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
May 31, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air bake element problem Model SVB46800w
At the family house we had an old counter top Jenn-air appliance and the connectors for the elements always burned until i put white sillicon grease on the contacts.This grease is intended to transfer the heat on transistors. Never had problem again.
Jul 29, 2008 | Jenn-Air Ovens
Bottom element burned out, replaced with a new one
there does appear to be a high limit thermostat located on back wall, diagram not really clear where but would be wired inline with the bake element . if thats blown there would ne no bake/ probably no broil either
Mar 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Sve47100 oven doesn't heat
Some times a company changes vendors for the controls and connections change location. But does the wiring diagram indicate a relay board in the back of range. It could be damaged form the element short
Jan 03, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Bake oven element blew
Could be the oven selector switch or the thermostat that failed form thhe element shorting out. You will have to have a ohm meter to check these
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
733 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
