Question about Coby DVD-224 Player
I bought this particular unit, years ago. And, though I don't watch dvds very often, the remote control stopped working this week. I thought that the reason was because of the batteries that were in the remote. Yet, I put those same batteries (2 AAA's) in another remote I have that uses that same type and the remote worked. I put brand new batteries in the Coby remote and it still doesn't turn on the dvd player or operate any other feature. I have never dropped the remote on the ground since I've had it. How do I get the remote working again, or how do I obtain a new one? And, for how much $$? Thanks.
    President:
  • 1,140 Answers
Apparently, the original remote is no longer available, but it always worth trawling eBay for used remotes. I've found many unavailable remotes for customers there. Remotes.com have a substitute remote available for $19.99 plus $7.95 shipping = £27.94 total.
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12895166582000&smodel=DVD224&brand_pn=COBY_DVD224
I will try some other sources and will post back if I can find an original.
Regards,
BElectric
Posted on Nov 11, 2010
  • DILLIGAF
    DILLIGAF Nov 11, 2010
    You can also try this which will cure some "dead" remotes:
    Step 1 - Pull the batteries out of the remote and leave them out until Step 4.
    Step 2 - Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
    Step 3 - Put the batteries back into the remote, being very careful to install them correctly.
    New batteries should be used if you're not sure about the old ones.
    Step 4 - Try the remote.
  • DILLIGAF
    There are five (used) available on eBay - the cheapest is only $8.99 plus $7.99 shipping.
    http://cgi.ebay.com/140476110377
How long should a bulova watch work ---my husband bought me a bulova watch 7 years ago ----it stopped working & I thought I just needed to replace the battery ----so I did but less than 3wks later the...
I would expect the battery to last more like 3 years than three weeks.
Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery?
I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced.
Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
Oct 14, 2017 | Bulova Diamond Watches
Our remote control has stopped working. We only bought the set 2 weeks ago and used the batteries provided. It stopped working 2 days ago. We have replaced with new batteries and nothing happens. The...
either the remote is bad or on the tv the circuit board at has the remote receiver on it is bad. If you bought it new and it has a warranty contact them for service. If not you could try programming a universal remote to see if it will work your set.
Sep 11, 2010 | Televison & Video
Keyless remote controls stop working all of the sudden.
you can re program the re motes yourself but it is a long program to type see if your local pepboys or autozone has a copy of autodata key programming and service indicators it lists your remotes and tells you how to reset the codes and programming in the remote. If you cant find it let me know a fax number and i can shoot you a copy out of my book
Sep 02, 2009 | 2004 Toyota Camry
All remotes controlling my Onkyo TX-SR304 stopped working
try putting the remote an inch away from the IR receiver on the unit and see if it works then, if so then you definitely know its broken. This can and does happen. From what you have posted it sounds like no remote is working on the receiver, the ir receiver can break. If you need further assistance let me know.
Thank you,
Lee
May 28, 2009 | Onkyo TX-SR875 Receiver
Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Mar 15, 2009 | Kicker ZR360 Car Audio Amplifier
PS3 randomly mutes my TV, Mostly on DVDs
it sounds there is a lose connection inside the ps3 somewhere not sure though hope this is any help to you.
Feb 07, 2009 | Sony Playstation 3 (PS3) Console
DVD Regional Error
Im not familiar with yours, but some DVD players, particularly PC drives can change regions a set number of times (for pc its usually 5)
So the last change that it made, it locked there. That is why regionless discs will work, but others wont.
If you have many discs of different regions try a few (particularly of the last that worked) and see if there is a pattern. Also look in your DVDs menu to see if its mentions what region its set to.
Jun 07, 2008 | Audio Players & Recorders
Citizen wrist watch stops working
A lamp may be to hot while the light may not be sufficient. Put it in a window sil for a week or so.  Look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
May 25, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Coby DVD-224 Player Logo
272 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
