Question about Logitech M-RBB93 Mouse
What is passkey for m-rbb93? tried 1234 but does not work?
Need help w/ finding bluetooth passkey for SGH-T929
Phones do not have passkeys, a headset does have a code which is typically 0000 or 1234 but your phone does not have a passkey what do you want to connect it to?
Apr 04, 2011 | Samsung Cell Phones
I bought this bluetooth for my gaming system and when i tried to connect it, it said i need a passkey and i do not have the passkey
Look in the manual for your bluetooth headset for the default pairing pin or passkey. It is typically "0000" or "1234".
Mar 16, 2011 | Computers & Internet
I need the passkey to install the bluetooth to my new phone, motorola H681
the default passkey for every bluetooth device is usually 1234. try it and let me know if it works. u have to pair it and enter the same passkey with your mobile/celfone.
Aug 07, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Bluetooth passkey for panasonic RPTR124132
The stock passkeys usualy will work 0000 1234. check in the manual it should show you the options but try thoes or 00000 12345 or just leaving it blank will work with some models.
Nov 17, 2009 | Cars & Trucks
Blue tooth connection passkey
Most Bluetooth devices uses '1234' or '0000' as the default passkey. Since you tried using '0000', you may wanna try using 1234.
Have a great day!
May 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
Im trying to set up my bluetooth on my cell phone. It finds my bluetooth an H700 motorola then I press pair and it says to ENTER PASSKEY, I dont know what it is. I tryed 1234 and it says failed to...
passkeys should be entered for both devices.
like when you are trying to paired your phone with you friend's
it would then asked to type in a passkey, you can type in any passkey you like but it should be same combination with your friend's. (so you can use 1234 punch in on yours and your friends need to use 1234 code punch in his phone, so both bluetooth device will be paired successfully).
Apr 28, 2008 | Cell Phones
My lg 710 passkey won't work help please
hey yeah i had the same problem and so i tried all the other known passkeys and 1234 worked for me. so good luck hope it helps.
Dec 30, 2007 | Radio Communications
Passkey of 4 zeroes does not work
I have the exact problem.. but you try to turn off and on your phone once again.. and then do the pairing instruction.... using the passkey 0000.. then... it works for me again...
Oct 12, 2007 | Jabra BT350 Bluetooth Headset Headset
Logitech M-RBB93 Mouse Logo
156 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
