Question about RCA Televison & Video
My tv doesnt power up - RCA Televison & Video
  • 4 more comments
  • jtharpe1775 Nov 11, 2010
    Its an RCA Model # D52W20B PROJECTION HD
    COMPLETELY DEAD!!
    NO ITS DEAD
    no its dead there's no sound of it trying to come on.
  • jtharpe1775 Nov 12, 2010
    the 2200 uf is green and the other is shorter either brown or black correct?
    you wouldn"t happen to have a picture of it or a schematic so I can be sure im @ the right place?
  • 10,515 Answers
Kindly mention the make and model of the TV?
Thanks!!
Posted on Nov 11, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Nov 11, 2010
    Thanks for your response!!
    One more detail - Is it completely dead or it turn off as soon as you on it?
    Thanks!!
  • taran_2005
    taran_2005 Nov 12, 2010
    Unplug the TV for few minutes, say 15 minutes and then turn it ON. If the problem persists, this would confirm an internal failure. This unit has a 2200uf and a 220uf capacitor on 6v line that swells, these caps are blown, the location is cp150 for
    the 2200uf and the other is right next to it, if they are swollen
    replace and you will be fine.Also, check the ribbon cables - make sure that they are in the connector securely, My trick is to pull them out, and
    with a dental pick push on the metal connectors, so when you insert
    again it is tight, if the connector looks bowed this is the problem
    secure by pulling and replacing. only do this if the caps are OK.
    You need to take all precautions while opening the TV for repair.Use of multimeter and soldering iron could be there.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    Unfortunately, i do not have the picture, however if you could upload a clear pic of the board, i could mark few caps.If you want to have the complete service manual, you could buy it from :-
    http://www.servicemanuals.net/ServiceMan...
    Hope i helped you.
My mitsubishi vs-4541 clicks like it is turning on but the power light doesnt come on and neither does the tv
a old set-----power supply problem or bad solder connections in one of several areas of power or deflection boards--very common on this set---unless something easy it is not worth a shop repair as many of the parts used are no longer available.
May 15, 2012 | Televison & Video
Tv wont turn on by pushing power bottom on
pull out the plug for 3 minutes and then back in again. maybe that works!
Dec 03, 2011 | Televison & Video
37" hitachi plasma tv doesnt turn on
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug,
( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix.
pete
Nov 10, 2010 | Hitachi 32HDX60 32 in. Plasma Television
LCD TV samsung LN40A450 doesnt turn on
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Jan 18, 2010 | Samsung LN40A450 LCD TV
RCA TV that doesnt power on
most likley the capasitors on the power supply board are bad
if u take apart and inspect them u may see the tops have a slight dome shape giving indication they are out of range
Nov 26, 2009 | Motorcycles
My Poloroid LCD TV wont turn on power supply brick light doesnt
The TV needs a fairly stable and well filtered 12V power supply. A jumpstart box is 12V, but is I seriously doubt that it is anywhere near filtered and stable, so most likely you would smoke the TV.
Hooking the TV directly to a 12V battery is just fine, as long as the battery has enough current to run the TV.
Oct 20, 2009 | Polaroid LCD-2000 20 in. Television
RCA TV THE FAN DOESNT WORK I THINK THE FAN COOLS
yes it does keep tv cool. The fans do wear out, but sometimes the circuit that powers the fan can have overheated or burnt out capacitors and won't send power to fan. You can test power with a voltmeter and capacitors with an ohmmeter. You can parts at shopjimmy.com
Oct 13, 2009 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
