Question about Samsung HLP4663W 46" Rear Projection HDTV
Where can I buy replacement color wheel Code: bp67-00099A
I am thinking about buying a Samsung 72" DLP (Hlt7288wx/xaa) for $500. The seller says a tv repairman says it needs a color wheel replacement. Do you think this is something that would be difficult to...
Yes,tvs with a colors wheels design into it are more prone to brake down and more quickly than tvs without colors wheels design into it.The colors wheel in the tv spins at 12000 RPM at every cycles to make and let the tv Light Engine shine a beam of light into a colors wheel to make and have a colors spectrums to make it to works for the tv.No projection tv with a colors wheel are not easily to be replaced have go through alot of trouble to replace a colors wheel itself.The tv colors sit way back of the tv have to take out many tv mechanical tv frames bulk heads even than can come to the tv colors wheel itself to replace it.Take ur $500 buck buy a "40 LCD tv less worry less head aches.
Aug 22, 2011 | Samsung HLT7288W 72" HDTV
When I turn my tv on it just hums and it sounds like it wants to cut on only the lamp and the standby temp lights come on can anyone help me out here? I also just installed a new lamp and it's doing...
You have a bad color wheel that is broken. To get the right one you must have the model number and the version code. The version code is on one side of the TV at the back. Will be two letters and two numbers. Installing one can be a bit of a pain if you have never taken one out and replaced. You have to pull back the light engine to see the color wheel. The light engine is the main box like module that has the projector lense. A screw(s) holds in the color wheel and has a wire plug to it as well. Do a search on Google or Ebay etc. to find the part to purchase. Again the version code is very important! Before buying I advise that you take the color wheel out to inspect it for damage. When installing the new color wheel DO NOT touch the wheel itself.
May 24, 2011 | Samsung Televison & Video
COLOR PROBLEM ON MY SAMSUNG DLP
good day
your problem is in the color wheel..because when the color wheel malfunction or out of timing the color of the screen is not good
color wheel is available at the market you can buy it to eBay.com or amazon.com
replacing of color wheel is D.I.Y. its easy for you to perform
watch this video to guide you the proper procedure
thank you and good luck..
Apr 07, 2011 | Samsung Televison & Video
Buy a cheaper color wheel !
Sorry, the color wheel is only available in the Light Engine Assembly. You can not purchase it as a single part. You will have to purchase the engine and replace it to repair your TV. PN: 23405476 it runs about $450 with a $200 core. You may find it cheaper... I don't think it is readily available... Best of luck to you, I hope this was helpful.
Mar 26, 2010 | Toshiba 62HM95 62" HDTV
My Toshiba DLP makes a humming noise. Replaced the
Color Wheel. Call Encompass Parts 1-800-638-3328
Dec 30, 2009 | Televison & Video
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Want to know if color wheel can be repaired?
Unfortunately, you can't replace just the bearing. You would have to replace the complete color wheel. Here's a link for a major parts distributor so you can get an idea on priceing:
RCA HD44LPW62 Replacement Part Color Wheel
Jan 23, 2009 | RCA HD61LPW165 61" Projection HDTV
Toshiba 52HM95 Color Wheel
Why not buy one and replace it yourself? why do you think its the color wheel, is the bearing bad? Is a color stuck?
Jul 04, 2008 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
412 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
