Question about York Furnace Draft Inducer Blower Fasco # A224
Furnace lights but fan motor wont start - York Furnace Draft Inducer Blower Fasco # A224
  • wathow Nov 14, 2010
    Thanks, I will order a new circuit board today!
  • 43,501 Answers
I am assuming that the blower in question is the indoor blower motor and no the inducer fan...
The problem is usually caused by a bad circuit board relay and actually is a very common problem...
To be sure... you can jumper the 110 current directly to the motor and see if it will run...
If it does then ...
Replace the circuit board and you'lll be working again....
heatman101
Posted on Nov 12, 2010
  • steviebb27 Dec 21, 2010
    By furnace would light and he blower wouldn't turn on also and it hummed a bit and the outside of the blower was hot to the touch which tripped the Aux High (4 flashes error). I first hit the reset between the 2 brown wires connected together on the outside of the blower, which did not work.
    I then replaced the 10 MFD 370VAC Motor Run capacitor (check yours to see if it is a 7.5 or 10 MFD), which is the metal cigarette box shaped part the rest on the outside of the blower.
    It cost me $7.09 at a local electronics store and now the blower works!
    Just something else for people to try!
Coleman presidential furnace
bad fan control switch or bad fan motor
Nov 28, 2017 | Coleman Heating & Cooling
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
I have a bryant gas furnace plus 90 the furnace kicks on and the pilot lights but the fan that blows the heat thru the house wont turn on! I keep getting error code 44 and 41 what can i do to fix that?
make sure fan wheel turns freely
check for voltage to fan--if you have voltage check capacitor output against capacitor rating, must be withing 5%, if that checks out replace blower motor
Jan 17, 2014 | Heating & Cooling
My heil n9mp2 isnt working just hums
is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
Jan 06, 2013 | Heating & Cooling
Rheem furnace problem wont stay lit
You need to see what it does. Does it light at all? will the pilot stay on? If lights but wont let you release the knob then thermocouple is bad. I
If it is electric start then watch the series of events. enducer fan motor starts, element heats up, gas lights but shuts off after 1 second. 5 seconds 1 minute and so on. Also your computer board on the furnace will flash a code indicating a problem. count the flashes and read the panel on the furnace for help it should give a description of the the errors.
all depends on the age and type of unit. respond if you have more questions .
Feb 15, 2011 | Heating & Cooling
Furnace lights fan comes on then fan goes off furnace stays light until overtemp takes it out code flashes 4
Have some one hold the bottom door safety switch, turn furnace on wait until heating fan relay clicks, and check at terminal (Heat) & terminal (neutral or where all the white wires are located on the control board) for 115 volts to 120 volts. If voltage is present replace blower motor, if voltage drops out while running then replace control board.Turn power off to furnace, open bottom door and feel blower motor with hand, if motor is real hot replace motor. you can not oil this type of motor, it has to be replaced along with the compacitor. Good luck.
Jan 22, 2010 | Goodman Furnace Draft Inducer Blower ...
We have a dayton gas furnace model #3E463A. thought the control box was gone. got new one we furnace starts up the power goes on, fan starts no green pulsing light on control no ignition
When your furnace starts...the Ventor motor(exhaust fan) starts up....within a short time (seconds) the Pressure switch closes proving that the Fan is indeed running and the vent is not blocked...if this doesnt happen the furnace will not poweer the ignitor or fire at all....Check the vent pipe outside and look for obstructions or dirt on the screen inside the pipe...the condensate from the fuirnace may not be draining at all...due to plugged condensate drain lines...find this tube coming out of the furnace front...bottom of upper compartment usually , and pull it off the tap....if water starts coming out then your drain is plugged downstream of the furnace.
Oct 25, 2009 | Dayton Gas Furnace Heater
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Bryant furnance clicking, won't fire
try checking the pressure sensing switch,it has a tube that should run somewhere close to the inducer fan.sometimes this hose fills with liquids,and makes the units act funny.I don't know if you have a condensing unit or what.the furnace wont try to light if it cant tell the inducer motor is running.any induced draft unit will work this way.you can also do a temp. bypass of the pressure switch to make sure the contacts on it are closing just be sure your inducer fan is running,and you cant leave it like that its just a test.that is a safety feature you really need.
Mar 11, 2009 | Heating & Cooling
Suburban RV Furnace
make sure fan is set auto its just seeing fan motor now
Jul 06, 2017 | Dometic Rooftop RV Air Conditioner
York  Furnace Draft Inducer Blower Fasco # A224 Logo
848 people viewed this question
Top York Tools & Hardware - Others Experts
vince
Paul Carew
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
