Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
The toner was low, so I changed it. however, when I try to copy with a new toner it is still blank.
  • 1,110 Answers
I have a tip posted here at Fixya that addresses the blank copies issue with the Canon 6500 series. The link is posted below. I think you may find it very helpful. If so please return here and let me know that it helped.
Thanks,
WheatlandServices
http://www.fixya.com/support/r6672478-canon_imageclass_mf6500_series_copier
Posted on Nov 11, 2010
It just won't make a copy. New
do you mean that copy comes out blank?
If yes, this is problem with laser shutter on laser unit.
Call service!
If the copy isn't blank, please give more details about problem...
Sep 14, 2011 | Canon imageCLASS MF6530 Copier
Blank copies on brand new Toshiba e-Studio 120
Did you pull the plastic tape off of the toner cart?
Feb 18, 2010 | Toshiba e-Studio120 Copier
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
Incoming faxes are blank outgoing faxes work ok. toner has been changed
Hello sir; Try to make a copy, if copy is OK then replace a new phone cord .if copy not OK still blank, that's means high voltage supply board have problem.
Oct 12, 2009 | Canon L120 Fax Laser Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Canon ir1510 blank copy problem, and always showing toner level low indication... but toner and drum is new... whats a solution.. pls any one tel me..
check the hopper motor of the machine. the motor near behind the toner. check if it turns. open the front cover. check the cover for switch activation. activate the switch and make a copy if the toner bottle turns the hopper motor is ok.
Mar 19, 2008 | Office Equipment & Supplies
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Image classD661 blank copy
If you just changed the toner cartridge, you probably forgot to remove the metal foil seal, from the side of the new toner cartridge.
Dec 07, 2007 | Canon imageCLASS D661 Digital Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
96 people viewed this question
old marine
old marine
