Question about Car Audio & Video
I parked my 1989 jeep cherokee last dec. And started it this nov. And can not get the transfor case to go in to 4wheel drive .when i shift there is no noise coming from the transfor case
    Sniper:
  • 59 Answers
So you can shift into 4 wheel but it stays in 2 wheel? If it shifts really easy into 4 wheel then you have a linkage problem (the linkage between the transfer case and the shifter, could just be that a piece wore out and fell off.) but if it feels like its shifting into 4 wheel then it would be the front end (could just be the vaccum line needs replaced.)
Hope this helped. But for more solutions you might want to post this in the Motors/cars category.
Posted on Nov 11, 2010
2002 Grand Cherokee Limited how to properly shift in and out of 4wheel drive
on the move for high and stopped in neutral for 4 low. gas on shift in gas on shift out. let up on the go pedal after you shift it and youll feel that click
Jan 18, 2018 | 2002 Jeep Grand Cherokee
How to engage the 4 wheel drive on a 1991 jeep cherokee
You can "shift on the fly" at up to 45mph - just let off the gas and pull the shifter back to 4hi. DO NOT try going to 4lo while moving.
Another way is to stop, put it in neutral, and pull the shifter back to 4hi or 4lo.
This is vacuum activated - so if you can't get it to engage - the vacuum motor is failed - or you have a disconnected or rotted vacuum line.
Cherokees have the command - track. You'll see a lever next to the transmission shifter that has letters 2H, 4H, N, 4L on it.
You can shift from 2H (2wheel drive high range) to 4H (4wheel drive high range) at any legal speed.
If it's an automatic, I recommend just taking your feet off of both pedals, so there's not a lot of torque being passed thru the transfer case.
If it's a standard I recommend stepping on the clutch when you shift, but it's not necessary.
To go to Neutral just pull the shifter back one more position to the N position. To shift into 4L (4wheel drive lo range) you must be stopped.
I also recommend shifting the transmission into neutral when you do this. Push the shifter to the right, then pull it back.
Thanks!
Oct 02, 2011 | 1991 Jeep Cherokee Briarwood
How do I get it out of 4wheel into 2 wheel drive?
A 96 grand came with 3 different transfer cases in different models. if you see beside the 4x4 shifter there is the shift pattern printed there. some models only had the all-wheel drive option with high and low. others had 2wd-4wd high-n-4wd low. I would guess that since you're asking this, your jeep has only the all-wheel drive transfer case option. if this is the case... you are not able to run your jeep in 2wd
Jan 17, 2011 | 1996 Jeep Grand Cherokee
1996 grand cherokee laredo quadra track will not shift easily if at all with out alot of grinding trying to get it back into drive. I am not sure exactly what i got . i needed 4wheel drive to get into...
youre supposed to shift that while moving unless you are going to go into 4 low. all 4 tires should be at least within 1/8 in of each other in diameter
Jan 11, 2018 | Jeep Grand Cherokee Cars & Trucks
89 cherokee popping out of 4 wheel drive
no nothing you did if you moved case sifter by hand then case is NO GOOD!!!!!, what a bummer!! good luck,
Oct 29, 2009 | 1989 Jeep Cherokee
Why does jeep only go in part-time 4-wheel drive and not full time?
Are you having trouble shifting into 4wd?
Some of the GrandCherokees come with full time 4wheel drive viscous coupling inside of the transfer case and some have teh 242 TC which allow you siwtch between 2wd, 4hi, N, 4lo.
Oct 25, 2009 | 1996 Jeep Grand Cherokee
89 jeep grande Cherokee limited stuck in 4wheel drive.
the link for the 4wheel drive pops off the trany, get under the jeep and push it back in,, you may need to get a new clip,, not hard to do
Oct 22, 2009 | 1989 Jeep Cherokee
Can I tow my 4X4 auto grand cherokee behind a Mtr Hm? I will put everything in N (transfer case & Trany)
I have a jeep wrangler and to have it towed you are suppose to put the transverecase in neutral after you first depress brake pedal put trans in neutral then start engine shift auto trans into drive release brake pedal make sure there is no movement, shut engine off with key left in acc position shift auto trans into park, disconnect neg battery cable (damage can result in trans if shifted into park while transvere case is in neutral with engine running) you should refere to your owners manuel
Jun 27, 2009 | 1997 Jeep Grand Cherokee
4x4 on 89 jeep cherokee laredo
Just pull up on the 4 wheel drive lever .. You can shift on the fly to part time and full time but you gotta stop and in park or neutral you can shift into 4 wheel lo .. I have one myself .. love those jeeps .. you "understand"
Mar 03, 2009 | 1989 Jeep Cherokee
Jeep Quadratrack does not shift into 4 wheel drive
the quad trac is an alltime 4wheel drive system. it does have a control module that helps transfer the power from front to rear. if it is a 2008 it should be under warranty and you can have it checked out for proper operation
Dec 21, 2008 | 2000 Jeep Grand Cherokee
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
