Question about Yamaha RAV-205 Remote Control
I have the YAMAHA RX-V2095 with no remote controll-need advice i found the rav 206 in secound hand shop but the setup is not working what can i do about (is there a code to program the 206) or what remote shuld i use beside the orginal RAV180 Regards Avishai Kes
  • akes Jun 17, 2008
    i have the YAMAHA RX-V2095 with no remote controll-need advice
    Regards
    Avishai Kes
SOURCE: Openning the Yamaha RAV -206 remote
hey hows it going i also have the same remote.
what youll need is a #4 (small) and remove the two samll screws under the battery's. also you will need a small screw driver (flat head) it would be better if you have two.
what youll need to do is start in thecenter of the remote and slide the screw driver down the side of the remote keep one screw driver in as you slide and pry the remote apart. there are four latch's on the remote on each side (three along remote bottom center and top)
also on each side of the infared light that should be it just repeat the process on the both side and u should be good.
Cullen
Posted on Apr 24, 2008
My RX-V2095 Yamaha receiver won't power up.
Wont power up, or stuck in "protect mode"? Unplug the unit & let it sit for a couple hours, then plug back in & listen for a "click" a turn (power supply relay energizing.) If no lights & no click, the first place to check is the mains fuse. If the unit is under warranty - take to an authorized facility & they will take care of it for you.
Oct 20, 2014 | Yamaha Rx-v2095 7ch Flagship Home Theater...
My RX-V2095 cuts itself off about 3 seconds after I power it on. I have unplugged it from the wall to give it time to reset itself and unplugged all components and speaker connections and still I get the...
Try setting the "Auto Power Down" in the "Setup" menu to "off". Double check the selection of the speaker impedance on the back of the unit to make sure it matches your speakers.
Feb 19, 2014 | Yamaha RX-V2095 5.1 Channels Receiver
Have Yamaha RX-V363 with remote RAV 284 not able to find code for Panasonic Blu-ray DMR-BW750 or LG 47HDLED-LCD known as 47LH90QD, help please. David
chances are that the yamaha rxv363 will not control the bluray since it was produced before the bluray. as far as the LG codes, you may want to try a Zenith codeset. they are similar.
Feb 23, 2010 | Yamaha RX-V363 Receiver
Set TV Code for Yamaha Remote RAV-290
Do any experts know the answer to this question? It has been posted multiple times, but I dont' see any answers! It is a pitiful manual that is provided by Yamaha for this purpose and nothing is intuitive about making this work. If anyone know the answer, PLEASE POST IT!
Jul 12, 2009 | Yamaha RAV-300 Remote Control
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
Cullen
Oct 27, 2007 | Yamaha RAV-2000 LCD Touchscreen Remote...
Televison & Video Logo
423 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
