Question about Mad Dog Multimedia Computers & Internet
I am trying to burn 16x dvd-r discs but it keeps saying disc is full, when i click properties it shows full in the blue but no files are on the disk
  • Mad Dog Mult... Master
  • 27,725 Answers
The cd/dvd burner might not be getting enough power
make sure the leads that are attached to your cd/dvd drive have secure connections and are not bad/faulty or just replace them include electrical extension leads
or you might have bad batch of rewritable cd/dvd's
hope this helps
Posted on Nov 12, 2010
Asus 53 n laptop
1. option - Removing Windows 8 by installing Windows 7 over it*:
Go to the disc where you have the Windows 7 installer.
Then right click, click on Mount, when done, click on the Setup file and install Windows 7 over your current system.
2. option - Keeping Windows 8 and installing Windows 7 alongside it**:
Restart the Windows 8 system, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 .iso file on.
3. option - Running it from a DVD, but keeping/removing*** Windows 8:
a) go to the disc where you have the Windows 7 .iso file installer.
b) move the .iso file to a easily accessible place like Desktop.
c) then right click on the .iso file and click on Burn disk image, choose the DVD you want to boot from ( You need a readable DVD), and then check the checkbox which says " Verify disc after burning ".
d) click on Burn.
e) when that is done, close all open programs or/and windows and restart your computer, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 installer on.
Note - please read everything carefully. I suggest you to use the 3. method.
* - when in the setup, you have no option to go back to Windows 8.
** - this step might not work, because not all computers support that.
*** - you can choose to either create a new partition on which you will install Windows 7 or install it over Windows 8 by either kepping or not keeping your personal files.
Please reply to this solution: did it help you or not and what improvements in my solutions do you want, and rate my solution from 0-5.
Jan 12, 2013 | Computers & Internet
Remove Write protection from DVD disc
1. Insert the DVD disc into the computer's DVD-ROM burner drive. Click on "Burn files to disc" from the window that automatically pops up.
2. Type a name for the DVD disc in the "Burn a Disc" box. Click "Show formatting options" and choose a formatting option.
3. Choose "Live File System" to allow files to be copied immediately to the DVD disc, much like sending data to a USB flash drive or floppy disk. Live File System discs can only be read by Windows XP or later versions. Choose "Mastered" to have files be copied to the DVD all at once. This is the standard burning method; discs can be played back on any DVD-ROM drive.
4. Click "Next" to prepare the disc. Files can now be copied to the disc using the selected method.
Sep 04, 2012 | HP Computers & Internet
Hi i am using vista, and am using dvd shrink 3.2 version to burn dvd discs i open my disc in dvd shrink then back up in dvd shrink to file created in documents, then dvd drive ejects disk and asks for...
you must remove the region lock off the DVD image you're trying to burn make it region free. your DVD player might have locks on which DVD regions you can play, your DVD writer doesn't come with a region lock that's why you're able to play the disc
Sep 21, 2009 | Ritek /RIDATA DRD+4716-RDSM50 16X DVD+R...
16x dvd-R dISCS
Can you read from the CD-RW drive? If you can then the optics are most likely fine. Try reading from the disk you are trying to write to. It should show a lot of space available if you check it's properties. If not, then that disk has likely been closed and you can't write to it any more. If you can't see the drive on your computers HARDWARE viewer, then the drive either isn't connected (you have said it is), or power isn't getting to it. If you can read from a factory produced CDrom, then you should be good to go.
Jan 27, 2018 | IBM Electronics - Others
Burning problem
Try different brand. Your Drive is a sensitive type and it only accepts some DVD-R brands. Also try DVD-RW disc. I had the same problem but not specifically the exact problem. My drive is cd writer only. Same problem, I just used diff CD-R brand like Imation and Philips and the burning works like a charm.
Jul 26, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Can't get Disc Info from the Recorder menu... it's gray.
Go to your CD-R icon under my computer and right click and select properties. This should give you disk information if you are using Windows operating system.
If it shows you that the disk is full its either the disk is really fully or it was finalised to avoid further writng on disk
If it show that the disk has nothing on it it means the disk is either a blank CD or its information was corrupted and youcant burn anything on it nor read as well
If the disk shows free space then you can burn on it.
Feb 20, 2008 | Computers & Internet
Writing to a DVD+RW disc
You need to use DVD software such as Nero that supports DVD-RW. from the app is where you would erase and so on
also make sure your blanks are +RW and not -RW
Jan 10, 2008 | Toshiba Satellite A75-S206 Notebook
Slow burner
well what you can try is
1.) Cleaning your registery out
2.) deleting all temp files
3.) defragmenting your registery
to do all the above you can use a product know as tune up utilities aviable here www.phazeddl,com type yune up in the search box and search it
4.) defragmenting your harddrive
to to this go into my computer
right click on local disc and click properties.
clicl tools the defrag
5 delete your preftech files
they are located in c:\windows\prefetch
6 empty your recycle bin
7 restart
ensure you have 16x media and your burningspeed is set to 16x
4x media means you can only burn at 4 8x at 8 or below, 16x at 16 or below
if all fails then you need to format and reinstall
dont forget to rate me
Jan 07, 2008 | Dell Dimension 8400 PC Desktop
Dominator 4in1 year purchased 2003
Some disc brands just don't work with certain burners, and that can result in the said error. Did the store give you a different brand when they replaced your old batch? this error can also be a result from burning too much to the disc, or from trying to copy protected content. If you're burning movies, I would suggest that you close all other programs while burning, and burn at the lowest speed. Regardless to the error, you'll get a better quality result. Good luck
Jun 17, 2006 | Mad Dog Multimedia Dominator...
Computers & Internet Logo
57 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
