Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
I can't get the onboard network connection to work. Wireless works fine. When I look at properties it says that it is connected.
    Guru:
  • HP Master
  • 2,178 Answers
The Ethernet jack might have a broken wire inside the laptop. Try a modem that uses a USB connection instead of Ethernet - if it works, then the Ethernet jack has an open wire.
Posted on Nov 11, 2010
I keep having this problem with my wireless saying validating Identity. And I can not connect to the inernet
Hi
for resolving your problem Click the network properties and select wireless properties,go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Chher
Jun 28, 2011 | D-Link DIR-615 Wireless Router
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
My computer was wireless until I changed modems becausethe old one stoppd working
If you are using Windows XP, you go to start --> control panel --> network connections --> right click on wireless network connections & go to properties --> go to wireless network tab --> delete / remove all the networks under preferred network box then click on view available wireless or configure then connect to your network by clicking on the name of your modem --> type in the wireless password.
May 01, 2009 | 2wire (1000-000057-000) Modem
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Can`t get wireless router to connect to pc. Have uninstalled/installed usb wireless adaptor no good. Router works fine on a wired connection on another pc nearby.`Wireless` pc 10m away from router has...
  1. Go to "Network Connection"
  2. Click Right "Wireless Network Connection" Go "Properties"
  3. Click at Internet Protocol(TCP/IP) and click "Properties"
  4. At General bar,. Click on Obtain an IP address automatically and Obtain DNS server address automatically and Alternate Configuration bars, click Automatic private IP address
  5. After all of this click "OK" and "Close"
  6. wait for 30 second and try to connect again
Nov 10, 2008 | Computers & Internet
Laptop won't connect to wireless
Hello :-)
Try going into device manager, and uninstalling your wireless network adapter.
Reboot your PC. It will automatically reinstall your wireless network card.
Now try your wireless connection. This often solves random wireless issues.
Jul 08, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Internet half works with wireless adapter
Kinda odd one this.. Have you checked properties of the wireless icon in control panel/network connections - check dns server is on auto? If so, start a dos shell, type ipconfig /all and see if the dns info is the same as the other working pc's you have.. Also when right clicking the network icon, select repair, instead of properties, that does a heap of things to correct problems..
Also, from another user on Fixya, try this..
you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
might help.. Rgds,
May 03, 2008 | Blitzz Technology (BWP712) 802.11g/b...
Server connection WRT54G
This sounds like your work laptop is configured to configure the connection manually. Do you use your wireless at work? If you do not use your wireless at work, then you need to open your network properties (WINDOWS XP, click start button, then right click on "network places" and select properties, then right-click on your wireless card and select properties). in the middle box, double-click on the TCP/IP properties, and in the box that opens, select the button to "configure my network automatically". Do the same for the button at the bottom (DNS). This should fix the issue. If you do use your wireless at work, then you will need to remember (put into notepad and save to desktop) the settings that are in there already, and then set the same.
Hope this helps. If not, then I can get more in depth with you.
Feb 02, 2008 | Linksys Wireless-G WRT54G Router
Dell c640 wireless connectivity problem
hi.
That's gonna be a permissions problem in the way the wireless device was set up originally. Go to network devices, properties (of the wireless connection) and check advanced options for permissions. Also check the way the firewall was set up, and if it allows the connection you are requiring.
Good luck
Nov 17, 2007 | Dell Latitude C640 Notebook
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
64 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
