Question about Echo Garden
Gas leaks and fills the carb and crank when the machine is setting
    President:
  • Echo Master
  • 1,545 Answers
Gas normally will remain in the machine after it is shutdown. It doesn't go anywhere unless you have a problem like yours. It is quite possible the very small needle valve in the carb is leaking, and not seating properly; letting in a constant flow of gas. It can eventually make its way out of the carb if the check valves are sticking open. Disassembly of the carb will be required and a good cleaning is in order. If the carb is leaking thru the gaskets, then they either need to be replace (good idea if aging some) with a gasket and diaghragm kit or the covers on the carb just need to be tighted up.Post back with the carb name and model and for more guidance if necessary.
Posted on Nov 11, 2010
I have a yard machine 742rl when gas I'd in tank and fuel line hooked up gas floods out carb and fills up Air cleaner as if there is nothing to stop and start flow of gas
Those carbs have a nitrile rubber needle and seat.
When the rubber becomes worn, they leak and need to be replaced.
This is not something the average guy can do so it's simply easier to replace the carb.
That should solve your problem.
Apr 18, 2016 | Garden
Why am i getting gas in crankcase?
You have a stuck float in the carb...the newer carbs a have a small valve that stops the gas from leaking to the ground when stuck..however it now goes into the intake and into the cylinder and open valves and eventual filling the engine with gas oil nix..I had this and found out don't mess with the carb..cause it will happen again..there is a quick and permanent fix..if your tractor has a gas shut it off if not apply one...first if you have gas in oil it must be takin care of now..it can and will fill the entire engine block..so here is the fix..drain the engine block change the filter then remove and ckean the plug..now tape or cover the plug..and slowly crank the engine to blow excess gas from the cylinder. Just keep the plug away..put oil,filter and plugs back..put on a gas shut off or if you already have one..keep it closed at all times when not in operation..here is the important part..when done mowing put the throttle in low and reach up and shut off the gas..let it run unti it uses up the gas left in the carb..when starting open the shut off and let open a few seconds to fill the carb..then start....you must do this eah time you shut it down and restart....or get the carb rebuilt not to say it won't happen again..your choice..good luck.
Jul 01, 2014 | Honda Garden
I have a 98 honda fourtrax 300 4x4 and it is leaking oil out of the overflow tube
please check oil level sound like to much oil in crankcase.darin oil and check for gas from faulted carb leak while not running.This would fill crank case with gas and cause oil over flow
May 22, 2014 | Motorcycles
I have a zoom 49cc x2 pocket bike. I have just bought a new carb and put on it. And my bike still won't crank. If I put gas in the cylinder it will bur n the gas and then cut off. What could be the...
Try filling the float with gas and trying it again. When you install a new carb especially on the smaller cc motors there is not enough of a draw to actually fill the float. You can try an old trick as well. Crank the motor over a few times while plugging the exhaust tip with your finger. After about 6 or 7 cranks pull your finger off while still cranking it. It just might do the trick.
Nov 03, 2013 | Motorcycles
Yardworks snowblower will not start with electric cord and to hard to crank
too hard to pull may indicate that it is hydrolocked. Fuel from the carb may have leaked into and filled the crankcase. Check the oil level and see if it is very very high. Watch out! The fuel makes the oil level very hard to see. If the oil is filled with gas than not being able to start is a good thing. The motor wont get enough protection from wear with that much gas watering it down! If the oil is watering down then drain it out and get some fresh oil. Make sure you turn off the gas between uses to prevent the carb from dumping fuel. Get the carb serviced to fix the problem too.
Jan 02, 2013 | Garden
GAS IS MIXING WITH OIL
the newer fuel has been making a lot of problems with the needle and seat in the carb the valve leaks over fills the carb and drains into the crank case change them and the oil you will be good to go
Jul 04, 2012 | Snapper Garden
I have a 1997 polaris indy xc 600 tripple that is getting to much gas and the crank keeps filling up with gas. It wont even start.
bad needle and seat in carburetors allowing gas leak by needle in carbs. Turn off gas when not in use and will help get by until you can replace them
Dec 28, 2010 | Polaris New Genuine Polaris Snowmobile...
Fuel in the crankcase
Your float valve is sticking - the carb fills up, the fuel runs out through the carb into the engine.
Get a new float valve, until then - turn the fuel off at night.
Jul 01, 2009 | 1988 Suzuki DR 750 S
Yam tdm850 oil leak from strange place under carbs
dont try to crank it the carbs float are stuck and will fill crank case with gas drain the oil turn the gas off tap the carbs with a small object then turn the gas back on try cranking it then
May 07, 2009 | 1999 Yamaha TDM 850
Garden Logo
504 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
