Question about HP DeskJet 812c InkJet Printer
My hp deskjet 812C printer will not print yellow ink. Old cartridge ran out of ink so I bought a new cartridge it did not print yellow - returned it, thinking it was a bad cartridge, got another one it still will not print yellow. I feel it must be the printer seeing that I have tryed with two new cartridges and it still does not work. The old printer as far as I know was still printing yellow.
  • HP Master
  • 7,733 Answers
I just changed ink in canon DeskJet 812c and can not get yellow ink to work. I have run service of aligning the print cartridges and cleaning the cartridges. Any suggestions?
hi, it maybe your ink problem, becouse after do the cleaning for many time but still cannot, try to use other or new cartridge and see what result, TQ
Aug 05, 2011 | HP DeskJet 812c InkJet Printer
My 812 c only prints black and magenta. I put in a fresh color cartridge, ran it through alignment, prime, and clean functions and still only magenta prints
The cartridge may be defective, but before returning it, try cleaning the electrical contacts on the cartridge and the printer.
Use a q-tip and distilled or bottled water.
Do not touch the part of the cartridge where the ink comes out, just the electrical contacts (dots) on the cartridge, and the contact points in the printer that they connect to.
After cleaning the cartridge, put it back in. If you still only get one color, replace the cartridge.
If the replacement cartridge does the same thing, call HP tech support.
If the replacement works, call HP and get them to replace the defective cartridge.
Feb 22, 2011 | HP DeskJet 812c InkJet Printer
The ink cartridges on my HP 812c won't move. What can I do?
You can probably throw it away, it's an old printer and the belt is probably broken that moves the print head back and forth. There are some good cheap printers out there even at Walmart.
May 18, 2010 | HP DeskJet 812c InkJet Printer
HP 970 Cxi. Problems with colour printing. Ink cartridge is new
I have the same problem. I suspect the ink cartridge part # 78 that you and I bought has problem. I plan to return it today to the vendor.
Nov 15, 2009 | HP DeskJet 970cxi InkJet Printer
Printer is only printing pinks. Just changed ink
Try cleaning the print head. Do this under the tools for the 812c (do not physically clean). You may have to run the clean utility as much as 5 times.
Aug 17, 2009 | HP DeskJet 812c InkJet Printer
HP 812C will not print yellow but everything else is A-OK Repeated cleanings have NO effect. Cleaned contacts on printer where it connects to cartridge, no effect. HP 23 cartridge only has about 10 pages...
HTML clipboardHi,
It you haven´t used your printer for a while It sounds like the yellow has clogged up in the print head.
Although you have ink you need to print something regularly about every 10 days to keep the tiny jets open
otherwise it´s like trying to pass a camel through the eye of a needle.
So the inks may have clogged up?
The empty weights are 65g C6615A [No. 15] black and
90g C1823A color ink cartridge
anything over that... 1g = 1ml of unused ink.
So if you still have ink you can easily unclog it with a HTML clipboard Magic Inkjet Flush Kit (find it on Ebay)
Or you can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
Hp deskjet 812c changed both ink cartridges but it will not print
It's Not possible to solve urself, contact service center
Jun 25, 2009 | HP DeskJet 812c InkJet Printer
My printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Nov 11, 2008 | HP DeskJet 812c InkJet Printer
New color cartridge won't print in correct color
Was this a new factory ink cartridge or a refilled one?
I have seen some reconditioned/refilled with the color inks refilled in the
wrong section.
Sep 25, 2008 | HP DeskJet 812c InkJet Printer
Hp deskjet 812c ink light blinks w new cartridges
Here write 4 step you do it step by step
1. remove safaty strip from the cartridge
2. clean carridge block contact with soft cloth
3. replace cartridge for short
4. replace carridge block
Feb 27, 2008 | HP DeskJet 812c InkJet Printer
HP DeskJet 812c InkJet Printer Logo
479 people viewed this question
Seeker5211
Seeker5211
