Question about Cycling
I would like to raise the handlebars. I have loosened the stem wedge nut and the handle bars will not budge. I've tried everything almost to the point of losing the ball bearings in the steering shaft. Are these handlebars even adjustable? I can loosen the stem bolts and the handlebar swivels up and down, but the shaft will not budge up or down. I'd appreciate any help you could give. Thank you, joe
    Guru:
  • 347 Answers
Hey joe - Sounds like you have a classic stuck stem. Here are a couple things to try.
1 - Loosen the stem through the top bolt so the wedge is loose, but not removed. The give the top of the stem a good hit or two with a plastic mallet. That should break the bond between the steerer and the stem. If that does not work...
2 - Use liquid Wrench and drip around the stem so it seeps in-between the stem and steerer. Let sit a while then try the plastic mallet again.
sometimes you will need to work the stem back and forth a bit by using the handlebars as leverage and bracing the front wheel between your knees.
If neither of these get your stem loose, then it's time to take into a bike shop.
BTW - stems have a maximum insertion/ extension. There is a line of max extenstion that should be on the shaft when you get it removed. If you discover that the stem will not raise your handlebars enough, then you can get a replacement stem with a higher shaft and greater angle to lift the bars up.
Posted on Nov 18, 2010
I want to raise my handle bars just a bit have unscrewed everything and still won't budge
There is a bolt at the top of the stem (the part that fits in to the fork and clamps around the handle bars) which is the only thing you need to loosen to raise the handlebars.
It should only need to be loosened 2 or so full rotations. (If you have loosened it a lot, tighten it back up a bit.) The secret is that you need to bop that bolt with a mallet. (The stem is held in place by 2 wedges- they jam together to make the connection secure. Sometimes they get a little stuck.)
If that doesn't work, try loosening the bolt another turn and bopping it harder.
(Make sure that you don't raise the stem up any higher than the "insertion point"- the series of lines on the stem to mark it's maximum height. And make sure that you don't damage the bolt from hitting it too hard.)
If that doesn't work- I'd recommend taking it to a shop. They shouldn't charge to much for the adjustment... all the shop's I've worked at would do it either for free or for under $10.
Sep 25, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
HANDLEBAR ADJUSTMENT
Depends on what style of handle bars you have or what you want to do. Do you want to change the handle bars? Change height?Change the angle or stem?
You need to know what kind of headset you have on your bike. Either you have a "Threadless" or a "Threaded" headset. A "Threadless" headset has a star nut wedged in the fork tube and a hex bolt that goes through a plug on the top of your stem down into the star nut to compress everything together. You can easily change stem angle, length and height with a new stem which is realitivly inexpensive. If you have a "Threaded" headset the riser tube and stem are all one piece and it has a split/bolt at the bottom of the riser bar. As you tighten the split/bolt it tries to seperate wedging itself in your fok tube making everything tight. Not as easy to change but just as inexpensive.
Either way or whatever you are doing to your bike you will need a good set of allen keys. Almost every bolt on a bike now is hex head so a set of allen keys is a must.
Sep 10, 2011 | Cycling
Girls 24inch glacierpoint magna bike can't raise handle bars seems like a allen type screw in middle of bar just turns and still can't lift bar does that need to be replaced or is it something else
If that allen screw just turns both directions, and it won't tighten and it won't raise up when you loosen it, then the wedge nut at the other end of that screw has already fallen off inside. Or it could mean that the screw is broken. Turn the bike upside down and see if you can remove the screw. If it is broken, the repair will be difficult, but not impossible for a bike mechanic. If the screw comes out intact, then the only thing holding the handlbar stem in place is a bit of rust. Put the bike back upright. Stand over the bike as if you were going to ride it. Grip the front wheel between your knees and twist the handlebars as if you were steering while preventing the wheel from turning with your knees. Once it breaks free, pull it all of the way out. Turn the bike over again and the wedge nut should fall out. When you reassemble, take heed of the marking on the handlebar stem so that you don't raise the stem too high. Good luck. Please vote if you found this helpful. Al K
Mar 07, 2011 | Pacific International Pacific Chromium...
How do I raise the front handle bars on my Schwinn Jaguar?
On most bikes (Jaguar is a broad category, with varying details) there are two bolts in the middle of the handlebars. One bolt squeezes a clamp around the middle of the handlebars. If you loosen that one, you can tip your handlebars up or down. You can usually see this entire short bolt and it's nut (actually you would loosen the nut.) The other bolt is the one you want. On this other bolt, only the head of the bolt is visible. This is actually a long bolt that extends down into the the handlebar stem. The nut is down inside the stem, and it wedge-shaped so that it jams the stem tight inside the tube that houses it. Loosen this bolt about two turns, but do not remove it. Just give it a tap with a hammer, to free the wedging of the nut. You will now be able to pull the handle-bar stem up. It will probably still be snug, so you will have to twist it back and forth to pull it up. Pull the stem all of the way out and take a look at it. There will be a line on the stem that tells you the maximum safe height to which you can raise it. Re-insert the stem at least far enough to hide that line. If this is not high enough, you can buy a longer stem to replace it. Good luck, Al K
Feb 03, 2011 | Schwinn Men's 26" Jaguar Cruiser Bike
Raise handle bars
At the centre of the handlebars you will note a bolt head that is separate from the ones that lock the handlebars in place. Undo that bolt in an anticlockwise direction. About three full turns should be sufficient. Now take a block of wood and place it on top of the nut to protect the surface of the nut. Get a friend to hold the bike steady because you will need both hands to keep the block of wood on top of the bolt and deliver two sharp blows with a hammer. The handlebars should now be able to be pulled up and down or at least twisted and pulled up and down. Tighten the bolt at desired height
Oct 05, 2010 | Raleigh Diamondback Joker Bicycle '10
How can I raise handlebars on a 26 in. Mountain bike (mongoose 21 speed0
You need an Allen wrench (a.k.a. hex key) to fit the bolt head right in the middle of the handle bars. Loosen this bolt just 2 or 3 turns then tap the head with a soft hammer or block of wood and a hammer. Then pull the handle bar stem up (and all of the way out so you can see how the wedge-shaped nut at the bottom of the stem works). Look for a mark on the stem telling you how high you can safely raise the bars (you have to leave enough of the stem inside the tube so that it will be strong.) Put it back in and tighten it up. If you found this helpful, please vote. Good luck
Jun 24, 2010 | Cycling
How do i raise the handlebars?
There are two bolts in the center of the handle-bars. One bolt (on some bikes this is actually 4 bolts) is used to clamp the handle-bars to the handle-bar-stem. You can see both ends of this bolt. If you loosen it, you can tip the handle-bars up and down, but not raise them. The other bolt you can only see the head of. Loosen this a couple of turns (don't unscrew it all the way) then give it a tap with a hammer. You will then be able to pull the handle-bar-stem completely out. Do this so that you can see the wedge-shaped nut at the other end of the bolt. You should also see a mark on the stem that indicates how high you can safely raise the stem. Put the stem back in to the desired height and tighten it back up. Good luck.
Jun 11, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
How do you hire the handle bars on a giant mountain bike
Hello. You will need an adjustable wrench. Then look at the center of the handlebars and you will see a bolt and a nut. Usually the nut is on the underside. Loosen the nut, raise the handle bars and retighten the nut. J.
Jun 01, 2010 | Giant Boulder Se Mountain Bike 19"...
Back ache, can handlebars be raised? - How?
The stem can only raised safely within the steerer tube end to a line etched on its quill. There are stem extenders or even fixed-angle higher stems.
The sccret to getting a quill stem to move is to loosen the center (vertical bolt a few turns and then rap it down with a mallet to unseat the expander wedge inside the steerer tube.
It's possible your frame is sized improperly for you and your preferred riding position.
I would recommend you go to a real Bicycle Shop for those assessments.
Apr 02, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
Cycling Logo
373 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
