Question about Itech Clip IIe Wireless Headset
Hello! i have the clip II mini.When i press the multifuction button it gives no response. What can i do?
I HAVE A SYLVANIA 7 IN NETBOOK FOR MY SON SYNT7WID HE TRIED TO CHANGE HIS PASSWORD NOW HE CANT GET LOGGED IN ON THE OLD OR THE NEW PASSWORD DONT KNOW WHAT TO DO ANY SUGGESTIONS
Sylvania mini:
If you are experiencing problems with your product, please
contact customer support before contacting your retailer.
Call 888-571-0866 or email: dgsupport@digitalgadgets.com
Try a reset before calling:
In the event your netbook cannot normally shut down or restart, press this
button with a pin or straight paper clip to restart the netbook.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | Sylvania G-Netbook
Hello, my CANON MP500 gives error 5B00. Please help me!!!!!
Try this:
5b00 error
press MENU button, SCAN button, COPY button, SCAN button.
wait a minute.
it may be enter into special mode: service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
Thanks, Joe
Jan 29, 2011 | Canon Office Equipment & Supplies
How to use the remote
If you're using a wired remote, you don't have to do anything special. Simply use the button on the remote instead of the shutter release button on the camera.
If you're using an infrared remote, set your camera's shooting mode to one of the remote modes. Quick-response mode fires the shutter when you press the button on the remote, Delayed mode gives you two seconds to hide the remote behind your back.
Sep 09, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Power comes on but the no response pressing buttons play eject or fasfwd or rew
hello,
have you tried using your remote to see what response it gives?
Feb 04, 2010 | Memorex MVD2042 DVD Player
The volume control is frozen on the lowest level.
The manual gives next steps to setup the volume:
1. Press Menu button to return to the Main Menu.
2. Move down to Settings and select it.
3. Select Volume.
4. Highlight the desired volume settings then press Select button.
Manual in pdf format for the Sansa Clip:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Dec 19, 2009 | SanDisk Sansa Clip MP3 Player
BT-710 headset clip mini II
Go to your bluetooth settings and make your phone discoverable, normally you need to hold the power button down on your headset until it flashes red and blue, then you will need to select the headset on your phone, the default code is usually 0000
Jul 30, 2009 | Nokia Cell Phones
My O2 Mobile device Locked Please Help Me ??
Do a hard reset, which will delete all programs/settings/contacts, but should resolve your problem.
Press the power/sleep button and reset button at the same time.
If that doesn't work try pressing the camera and sleep button and reset at the sametime, until the device resets or gives a message.
Mar 07, 2009 | O2 Xda II mini
Keeps restarting
Hard reset for these is hold com button and voice command button (together) then press soft reset button
Apr 02, 2008 | O2 Xda II mini
How to hard reset my O2 xda II mini
This is a link for your manual which will show you how to hard reset and all else you need to know. Hope this helps!
Mar 16, 2008 | O2 Xda II mini
Itech Clip IIe Wireless Headset Logo
26 people viewed this question
Top Itech Radio Communications Experts
My Bible
Level 1 Expert
Tom Chichester
wwlvictoria
wwlvictoria
Are you an Itech Radio Communication Expert? Answer questions, earn points and help others
